MachineAgeVictim Posted April 13, 2006 Author Share Posted April 13, 2006 Skip, the car does seem to run fine, except for the hesitation when given fast throttle (maybe the fuel pump should be a pusher) the valve I was asking about is inside the air filter, this one I don't know where the two vacume hoses go to from the bottom, they may not have been hooked up before hand here's the new filter on Link to comment Share on other sites More sharing options...
Skip Posted April 13, 2006 Share Posted April 13, 2006 MAV Air dilter looks rad. The valve I described is in the air cleaner, that's where it measure the temp of the incoming air. Only the hoses (to it and from it to the diaphragm) are plugged in on the bottom of the aircleaner housing. I can get pictures of the valve from my 78 Brat to compare. The hesitation is probably a weak accel. pump not the fuel pump. Pusher or pull push still fills the fuel bowl. Mine runs great. Link to comment Share on other sites More sharing options...
MachineAgeVictim Posted April 14, 2006 Author Share Posted April 14, 2006 yeah, if you could post a picture of where the two hoses go, that'll be great how important is it? should I not drive without it hooked up? Link to comment Share on other sites More sharing options...
