trevize1138 Posted April 8, 2006 Share Posted April 8, 2006 I'm trying to install a new CD/MP3 player in my wife's '00 Legacy and there's one last spot on the console cover I just can't get off. It's the part right next to the ash tray. I can't tell if the housing for the ash tray is bolted onto something and that's what's causing it not to budge or if I just need to yank a little harder. Of course, I'm nervous about just yanking harder. Don't want to damage something! Anybody changed out the audio deck in these things before and got an idea? Link to comment Share on other sites More sharing options...
njdrsubaru Posted April 8, 2006 Share Posted April 8, 2006 there are screwss at the bottom of the ashtray housing remove those two and you'll be fine Link to comment Share on other sites More sharing options...
trevize1138 Posted April 8, 2006 Author Share Posted April 8, 2006 there are screwss at the bottom of the ashtray housing remove those two and you'll be fine Ah ha ... that's what I thought. I wasn't sure, and they're a bear to get at. But, now that I know they're the key I know I won't be wasting my time there. Thank you! Link to comment Share on other sites More sharing options...
RBGERSON Posted April 8, 2008 Share Posted April 8, 2008 I am doing the same thing. Single disk change just spits out the CD and won't play them..so I want to remove the changer and clean it. Are the two screws in the ashtray holder on the top of the holder..screwed into the bottom of the radio bracket about 3" in? They are the only ones I can see/feel..what a bear if those are the ones you have to take out!!! I have taken out the drink holder. Link to comment Share on other sites More sharing options...
aircraft engineer Posted April 8, 2008 Share Posted April 8, 2008 sorry - I did it with a short phillips - but one of those articulated screwdrivers with the flex shafts and removable tips should give you better access. #2 IIRC Link to comment Share on other sites More sharing options...
yohy Posted April 8, 2008 Share Posted April 8, 2008 If it's the same as my '97, take the ashtray out and then at the top of the opening will be two screws. As mentioned a stubby phillips or an offset phillips will work. I have attached a pic that will outline the various mounting points, again, this is for my '97. Link to comment Share on other sites More sharing options...
