njchen24 Posted April 8, 2006 Share Posted April 8, 2006 Greetings: The pumpist might have some hearing problem while I am specifically asking for fill up Super; he puts regular in my 05 2.5GT tank instead. By the time I realize the mistake, it's almost 1/2 tank (7.5 galons) already and fill up the remaining tank with Super. I wonder if there will be any serious consequence to this error. Thanks in advance for your time and help. Link to comment Share on other sites More sharing options...
northguy Posted April 8, 2006 Share Posted April 8, 2006 If you're that worried, add some octane booster. Link to comment Share on other sites More sharing options...
Suzam Posted April 8, 2006 Share Posted April 8, 2006 Half a tank won't cause damage, just drive normally without racing around and fill it up again after burning off a few gallons of the mix if your worried. Link to comment Share on other sites More sharing options...
The Dude Posted April 8, 2006 Share Posted April 8, 2006 As long as your engine does not "knock", you should be OK. The ECU should be able to handle moderate knocking by retarding the ignition timing. If you experience severe engine knocking, which is unlikely, stop the car. Severe knocking can cause serious damage to the engine. It happens rarely, but knocking has been known to shatter a piston!! Link to comment Share on other sites More sharing options...
Ranger83 Posted April 8, 2006 Share Posted April 8, 2006 Not unless you beat on it. Check out legacygt.com. Link to comment Share on other sites More sharing options...
Distance Commuter Posted April 8, 2006 Share Posted April 8, 2006 My experience on cars with knock sensor is - the knock sensor will retard the timing as soon as it detects knock. So, you will probably never notice the knock. The retarded timing will reduce your performance, and maybe slightly reduce your mpgs. So don't expect top performance till you get the octane back up. Also, remember it can't retard the timing until it does detect some knock. So I'd depress the accelerator more slowly, so that you don't create a lot of knock so fast that the computer can't keep up with the needed adjustment. Link to comment Share on other sites More sharing options...
Ranger83 Posted April 9, 2006 Share Posted April 9, 2006 You can also get a dump from your ECU and see for yourself. Link to comment Share on other sites More sharing options...
nipper Posted April 9, 2006 Share Posted April 9, 2006 fill the rest up with preimum, then you will get a mid octane mix in the tank. Thats how some stations make mid octane anyway. You wont hurt it as long as the car isnt under heavy load. nipper Link to comment Share on other sites More sharing options...
njchen24 Posted April 9, 2006 Author Share Posted April 9, 2006 Thank you all for your valuable input and advices. For peace of mind, I will go to an autopart store tomorrow get some octane booster and fill up with the highest octane gazoline that I can find after emptying 1/2 tank. Do you think the ECU will accustom to this low octane gazoline permanently? If so, is there a way to reset it to factory default? Link to comment Share on other sites More sharing options...
Zefy Posted April 9, 2006 Share Posted April 9, 2006 Quote njchen24 Thank you all for your valuable input and advices. For peace of mind, I will go to an autopart store tomorrow get some octane booster and fill up with the highest octane gazoline that I can find after emptying 1/2 tank. Do you think the ECU will accustom to this low octane gazoline permanently? If so, is there a way to reset it to factory default? if your really that worried about your ECU becoming accustom to it just unplug your battery for 5-10 mins and it'll reset... nothing to worry about... Link to comment Share on other sites More sharing options...
njchen24 Posted April 9, 2006 Author Share Posted April 9, 2006 I just went to two auto parts stores (R&S Strauss and Pepboys). Most of octane booster contains MMT which is not recommended based on the manual. I get all octane booster brand that doesn't specify MMT in its label. However, how can I be ascertain these products does not contain MMT. Any additional input is greatly appreciated. Link to comment Share on other sites More sharing options...
nipper Posted April 9, 2006 Share Posted April 9, 2006 Since it is a one time mistake, you worry to much. Fill the tank with the best premium you can find, or drive with a light foot and run out the tank you have. nipper Link to comment Share on other sites More sharing options...
njchen24 Posted April 9, 2006 Author Share Posted April 9, 2006 You are absolutely correct. However, it is really difficult to keep a light foot when you drive this car. Don't you think? My really concern is I will make another irreparable mistake by forgetting that I have 1/2 tank regular especially during rush hour going to work . nipper said: Since it is a one time mistake, you worry to much. Fill the tank with the best premium you can find, or drive with a light foot and run out the tank you have. nipper Link to comment Share on other sites More sharing options...
johnceggleston Posted April 9, 2006 Share Posted April 9, 2006 how many mile are in a tank of gas, maybe 400??? if the life of the engine is 250k miles that's 0.16% the life of the car. use it up and drive on to the next gas station. njchen24 said: You are absolutely correct. However, it is really difficult to keep a light foot when you drive this car. Don't you think? My really concern is I will make another irreparable mistake by forgetting that I have 1/2 tank regular especially during rush hour going to work . Link to comment Share on other sites More sharing options...
okanagansubman Posted April 9, 2006 Share Posted April 9, 2006 give her sh*t anyways. its fine. if you here it pinging then take er easy. Link to comment Share on other sites More sharing options...
Juan Posted April 12, 2006 Share Posted April 12, 2006 In Oregon, there is NO self serve gas. I've had to pump gas as I manage a large "store" that happens to sell gas and which has gas monkeys who can't be counted on to arrive to work on time (ever had someone pump your gas wearing a white shirt and necktie?). I've mistakenly pumped 27 gallons of regular grade fuel into a Chevy Tahoe and simply handed them the receipt and thanked them. Ooops. You gotta watch out when others pump your gas. That said, next time you don't get your mid-grade as requested, make them GIVE you a bottle of octane booster; even if you discover it later and come back (with your receipt, of course.) It is also true, at our pumps, that mid-grade fuel is created/blended by pumping high-grade fuel into the mid-grade tank as needed. That's why some stations run out of high-grade fuel first when supplies are tight. Hope that Tahoe didn't blow. Juan Link to comment Share on other sites More sharing options...
