hogweed Posted April 8, 2006 Share Posted April 8, 2006 my fusible link problem has grown into something sinister:mad: now, many of the warning lights are on (abs, at oil temp, check engine) and the speedo and tach go dead when i step on the brake pedal and sometimes the car cuts out too. i'm wondering if there is an ecu and if so where isit? thanks, gregg Link to comment Share on other sites More sharing options...
njdrsubaru Posted April 8, 2006 Share Posted April 8, 2006 ECU is located under the carpet by the front passenger foot area, lift the carpet and you'll see a metal plate, remove that and the ecu is under that plate... .... good luck Neo Link to comment Share on other sites More sharing options...
3Pin Posted April 9, 2006 Share Posted April 9, 2006 Having any starting problems or low battery? Mine did some of what you describe before the battery took a dump. Link to comment Share on other sites More sharing options...
hogweed Posted April 9, 2006 Author Share Posted April 9, 2006 not really. the chg system appears to be o.k. it just blows the link and now it's doing this other stuff! ugh! i don't have time to look at it right now. thanks, g Link to comment Share on other sites More sharing options...
