uniberp Posted April 10, 2006 Share Posted April 10, 2006 '97 Outback 5-speed 150k miles. Time to tighten up the suspension. Are there progressive springs for stock height available anywhere? Any particulary rewarding bushing replacements? Are there Bilstein Touring class shocks for these cars? New balljoints, struts, tires are going in as well. Will 215/70 (1os)tires generally clear all mounts? No slammed or jacked recommendations please. Just looking for a better riding/handling all-weather highway commuter.:cool: Link to comment Share on other sites More sharing options...
Legacy777 Posted April 11, 2006 Share Posted April 11, 2006 What's your budget? You're probably not going to find anything specifically for the outback, however there are probably quite a bit of stuff from the normal legacy and impreza of similar years that would work. You could put Legacy GT springs & struts on your outback, which will probably lower the ride height from what it current is, and give you better handling....without "slamming" it. I'd suggest searching on Nasioc http://forums.nasioc.com/forums in the legacy forum for more information on what's swappable. Link to comment Share on other sites More sharing options...
ctoth Posted April 11, 2006 Share Posted April 11, 2006 I'm looking for the same thing for my 04 ts and can't find anything. Everything I found drops it 1.2" in the front and 1" in the back. Not my gig. I want something with a minimal drop if any at all. Link to comment Share on other sites More sharing options...
MountainBiker Posted April 11, 2006 Share Posted April 11, 2006 King Springs lists standard height presumably stiffer springs. Contact them to see how much stiffer they claim to be. You can see the Outback springs on page 21 of this application guide: http://www.kingsprings.com/kings_master_catalogue.pdf Link to comment Share on other sites More sharing options...
uniberp Posted April 11, 2006 Author Share Posted April 11, 2006 Thanks. They have "progressive" springs for the front, but lowered. There may not be such an item. Link to comment Share on other sites More sharing options...
outback_97 Posted April 11, 2006 Share Posted April 11, 2006 What about KYB GR2 struts? They're supposed to be stiffer than the OEM but not too harsh, sounds like that's what you're looking for. I'm planning on buying some very soon to go with my new Scorpion lift springs. They're around $350 for a set of four delivered, at least where I've been shopping (http://www.tirerack.com). There may be other places to purchase these but I've had good luck with tirerack in the past. Steve Link to comment Share on other sites More sharing options...
MountainBiker Posted April 11, 2006 Share Posted April 11, 2006 Thanks. They have "progressive" springs for the front, but lowered. There may not be such an item. They list springs that are lower than stock(L), stock ht(S), and higher than stock (H), for both the front and rear end of the Outback. What am I missing? 96-10/98 OUTBACK 2ND GEN Front L/S/H: KFFL-25/KFFS-25/KSFR-26 Rear L/S/H: KSRL-25/KSRS-25/KSRR-25 Link to comment Share on other sites More sharing options...
