Guest archemitis Posted August 14, 2003 Share Posted August 14, 2003 i dont know much about the ej series, but im gonna put it somewhere subaru never intended. are there better years for the engine, and the computer? and tranny? i want a ej22 i think, because my favorite junkyard is full of them, legacy mostly 94-96. anything i should stay away from? and a 5speed 2wd tranny... they must be all about the same right? any help would be greatly appreciated. thanks Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted August 15, 2003 Share Posted August 15, 2003 What are you putting it in would help. The 1990-1994 motors are pretty much all the same. There's little tweaks here and there with certain sensors, injectors, etc. The ECU's continually got tweaked, but I suppose their basic function should be the same. The EJ22 in 1995 got the single port exhaust heads, but did get larger valves, and some did get roller rockers. Also the EJ22 in 1995 went to an OBD2 computer setup. Link to comment Share on other sites More sharing options...
Guest archemitis Posted August 15, 2003 Share Posted August 15, 2003 mmmm rollerockers. 87 hatch, nothing super crazy. just want to pick the best one i can. Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted August 15, 2003 Share Posted August 15, 2003 I'd probably go for the 1990-1994 models so you can use OBD1. I don't know how much of an advantage the larger valves will give you vs. the dual exhaust port head design. You can get the roller rockers from the 1995-1996 models and put them on 1990-1994 models. Link to comment Share on other sites More sharing options...
archemitis Posted August 19, 2003 Share Posted August 19, 2003 i gotta have dual port heads, cuz thats the turbo manifold i already have:brow: will obd1 work good with a turbo at stock boost levels? Link to comment Share on other sites More sharing options...
subieman Posted August 19, 2003 Share Posted August 19, 2003 Sounds like your going to put a EJ22 into a EA81 Hatchback body? I'm doing the same swap starting next month. If your in need of computer and wiring diagrams go here http://www.kennedyeng.com/ I just received mine in the mail today.. Damn it's very very complete. It's for those VW Van people that use the EJ 22 in there cars. Good Luck.. Link to comment Share on other sites More sharing options...
archemitis Posted August 19, 2003 Share Posted August 19, 2003 wow. that might just be worth 20 bucks. i am starting next month as well. race ya! hehe just kidding, hoping to finish by spring. Link to comment Share on other sites More sharing options...
subieman Posted August 19, 2003 Share Posted August 19, 2003 Yeah $20 is worth more then months of headaches trying to figure that wiring out. Good luck dude.. and yes the race is on Link to comment Share on other sites More sharing options...
archemitis Posted August 19, 2003 Share Posted August 19, 2003 anybody got a 2.2 in a hatch yet? Link to comment Share on other sites More sharing options...
subieman Posted August 19, 2003 Share Posted August 19, 2003 here is a pic of one in a Brat Link to comment Share on other sites More sharing options...
Legacy777 Posted August 19, 2003 Share Posted August 19, 2003 Originally posted by archemitis i gotta have dual port heads, cuz thats the turbo manifold i already have:brow: will obd1 work good with a turbo at stock boost levels? OBD1 will be fine.....but it will depend on the type of ecu you use, n/a, turbo, etc. You may or may not get the control over tweaking things that you want......I'm not really sure how much tweakability you want, and what ECU format/platform you're starting with. Link to comment Share on other sites More sharing options...
archemitis Posted August 19, 2003 Share Posted August 19, 2003 thanks legacy777 thats what i wanted to hear! i want to use the na computer, cuz thats all that is in the junkyard. can i just plug a turbo computer in? will i then need turbo injectors and fuel pump? hmmm. i want to use stock subaru stuff, without getting into rising rate rugulators, and piggy backs. im thinking even if i cant tweek it at all i will be happy with a turbo 2.2:headbang: Link to comment Share on other sites More sharing options...
Legacy777 Posted August 19, 2003 Share Posted August 19, 2003 for a turbo mutant, you're probably better off using a n/a computer and adding the controls you want on. boost, a/f, and timing. You will need some additional control besides what the stock n/a ecu is capable. It is probably easier and cheaper to add on control then to add a turbo legacy ecu, and be required to run the turbo maf, injectors, etc. Plus you would have issues unless you hooked up all the rest of the sensors to the turbo legacy ecu, and then you get fuel cut and boost limiting on the stock ecu...... Link to comment Share on other sites More sharing options...
