eddygordouk Posted April 11, 2006 Share Posted April 11, 2006 *edit* found these on ebay and wanted to pick up a set, that is, if they can fit on stock RX struts and/or kyb gr-2s. are they or do i have the wrong thing...plus what would be a recommended pring height? since i would go for a little higher spring rate ( i would like around 210~) what would be a ratio for the front and rear? thhanks for any help *edit* Can I/should I convert RX struts to coilover with a ground control convertter setup? it sounds like it would be decent and my struts are dead yet, might as well make em but what does everyone think? Or should i jus do that to some gr2s instead? since u can get the small xt fronts . I really want the dampening abilities of the RX struts but with a higherr spring rate, i dont really care about hight right now and would only lower alittle if i wanted to... Link to comment Share on other sites More sharing options...
calebz Posted April 11, 2006 Share Posted April 11, 2006 Not specifically familiar with the ground control setup . Is it any different than any of the other aftermarket coilover sets? Link to comment Share on other sites More sharing options...
eddygordouk Posted April 11, 2006 Author Share Posted April 11, 2006 its the same, sad thing is is that the search on ebay for the setup returned nothing. It seems as though I cant find them anymore and all it does is return legit ground controls I would like to run a more decent suspension setup and i will keep my 13"s till i move on to my lug swap later on down the road, anyone have some ideas? Link to comment Share on other sites More sharing options...
eddygordouk Posted April 13, 2006 Author Share Posted April 13, 2006 no noe has any recommendations? Link to comment Share on other sites More sharing options...
970subaru Posted April 14, 2006 Share Posted April 14, 2006 "impreza coilovers" http://cgi.ebay.com/ebaymotors/97-01-Subaru-Impreza-Dropzone-Coilovers-New_W0QQitemZ8055090198QQcategoryZ33586QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
970subaru Posted April 14, 2006 Share Posted April 14, 2006 "impreza coilovers" http://cgi.ebay.com/ebaymotors/97-01-Subaru-Impreza-Dropzone-Coilovers-New_W0QQitemZ8055090198QQcategoryZ33586QQssPageNameZWDVWQQrdZ1QQcmdZViewItem look at some circle track racing suppliers too, they have lots of good options for assembling a coilover kit though the price will be similar to groudn control. Link to comment Share on other sites More sharing options...
