Trouble code 22
hey Kevin, glad to see you found your way to the board. I can check the Factory Service Maunal tomorrow or if we hook up sometime in the next week, I can get on Mitchell at school and we can look it up and figure it out. I shoulda told you to do that today but I completle spaced on it.
Originally posted by GLCraigGT
the speed sensor sits above the speedometer cable, where it attaches to the speedometer. It's has two wires sticking out of it.
Opps, :dead:
that isn't quite where the speedsensor is. You will need to remove the speedometer from the clustor. The thing with two wires attached to the speedometer is the speedsensor
