It's getting closer. (naked Subaru pics inside)
Roundeye
I yanked the bumper to see what I had to work with. I'm either going to adapt a Rock Crusher bumper for a Cherokee, or build a tube bumper from 4130 chromoly DOM tubing. BTW: Cherokees (Jeep XJ) and EA82 wagons are VERY close in body measurements. Parts like bumpers and roof racks can be easily adapted and will look good on a Subie.
I chose to go with a hood snorkel 'cause I have not found a pilar setup I like. One for a Cherokee would fit good, but that would be about 300 bills. Plus I figure if I ever got it in water up to the bottom of the windows (my snorkel height) it's done for anyhow as it would begin to float. I used a piece of a heater duct from a UH-1B Huey for the scoop. (surplus parts can be found online) 2 1/4 inch flexible duct for the hose and a PVC fitting at the feed-through in the hood.
I made the light bar from a piece of 1" square tubing and used 1 1/2 inch wide 1/8 inch thick flat stock for the legs, base and mount tabs. Suckiest part was pulling the headliner down to install.
Here's some pics....and NO, it aint done yet!:headbang:
more lights=needed on the rack
also with your snorkel like that be very carefull not to drive into water an anything resembing fast.Your snorkel would suck in the spash:eek:
It's not real clear in the pic, but the actual inlet is about 3 1/2 inches off of the hood. it can take a a little wave action over the hood. Also I added a particle/water separator: a series of small holes in the rear of the inlet to allow water/small trash to escape; the feed through in the hood sticks up about 3/4 of an inch to prevent sucking pooled water in the inlet should the vents become clogged. Again, if I ever get that deep, the fun's over. Mainly it's all about finesse. Water should be entered as to not cause a splash. A wake should be kept just in front of the car. If you haul @zz into a crossing you are done for anyhow. As for the lights...I need to up my alternator first. Picture at night raining and hot = lights, w/s wipers, A/C, stereo, amp = fried alternator........but I'm working on that too:brow:
put two batteries in and run the lights off the second one. then you dont have to worry about the alternator. ive been running 8 lights on the battlewagon (off and on of course, cant have a 360* radius of lights running at all times) for about a year now and havent had one problem with my alternator. also, if you hit any REAL water - you will MOST LIKELY get it in that snorkel intake. dont get me wrong, it looks great. i had a hood intake on the battlewagon first and it took two water crossings onto my windshield to refigure to the pillar. this is what i did on the battlewagon - (if it doesnt show up - its in my members photos section. i still cant figure out how to upload pics on threads and posts :mad: )
http://www.ultimatesubaru.org/photos/data/500/thumbs/battlewagon_snorkel.jpg
put two batteries in and run the lights off the second one. then you dont have to worry about the alternator. ive been running 8 lights on the battlewagon (off and on of course, cant have a 360* radius of lights running at all times) for about a year now and havent had one problem with my alternator. also, if you hit any REAL water - you will MOST LIKELY get it in that snorkel intake. dont get me wrong, it looks great. i had a hood intake on the battlewagon first and it took two water crossings onto my windshield to refigure to the pillar. this is what i did on the battlewagon - http://www.ultimatesubaru.org/photos/data/500/subie_snorkel.jpg
the top and bottom 90* bends are factory subie SPFI intakes. works great.
http://s46.photobucket.com/albums/f124/volcomey/?action=view&current=IMG_1362.jpg
I have considered 2 batteries. Mount the 2nd where the spare tire sat and use an isolator for charging. That is an option.
As for the snorkel, I don't plan on getting in water up to my windows. This car is unusually rust free and has a beautiful interior (read: not a beater). I'm not scared to pound on it, but I'm going to ruin it either.
More lights are in order. I want it like my Cherokee was: Lots of light up front, alley lights and rear lights.
thats where i mounted my second battery. modified the spare tire bar and built a battery tray. and yes, there is an isolator in there somewhere. all my subarus have graduated to the "no carpet" grade :clap: so i like to go in water now. as far as lights, ive 2 forward, 4 on the sides - top and bottom, and 2 in the rear. i can run all of em with no hiccups in the charging system.
