anyone use Lucas Oil Treatment ??
i use it in my tranny, and in motor. if it helps cool, if it doesnt fine. i too was tempted by the display case in napa. i only paid $8 for it so im not out too much money....unless my motor fries because of it........
~Josh~
I have used the Lucas oil treatment in a 91 Dodge Spirit that had a slow front seal leak. It helped to slow it down more. Probably nothing that any heavier weight oil would do. I also used the transmission fix stuff in that same car when it was showing some serious tranny problems. Very rough shifting, and periodically going into limp mode. I drained the fluid and added a quart of lucas with the refill and never had a problem again. 2 years and still going strong. I used the power steering treatment on my 98 grand marquis and it improved the sticky steering. So I am not sure what help or harm the oil treatment does, but some of their other products are great. As for the experiment done by BITOG, I never found any white frothy oil in that Dodge during oil changes. I am not discounting what he found because I feel Bob has a good reputation and a lot of knowledge in this area. Also, don't think about using it in cold weather. It gets very thick. When temps got down into the 30's, it was a bear to start. No problems in the summer.
