No boost?!?!?!
well i fixed a bunch of issues since my last post but anyways here are the engine specs to start. EA82T, Spyder intake, 87.5 xt wiring harness, K26 turbo charger, custom uppipe, external wastegate, and an intercooler.
now for my problem my car wont seem to boost i can get to 2psi tops in first and second gear WOT. in second at WOT it seems to stumble just a little bit. i have checked for exhausts leaks (stethascope style) and came up with nothing. when sitting still and revving the turbo sounds like it wants to spool fine (not siezed) i have checked the wastegate and it seems fine i even unplugged it to see if it was opening to soon and it still only boosted to 2psi
vac at idle(1000rpm) - 16lb/hg
vac off throttle - 22lb/hg
fuel pressure at idle - 30psi
fuel pressure WOT - 36psi
i am going crazy trying to figure this one out!!, if you have any ideas i'll take them!!!!! thank you!
