DerFahrer Posted April 14, 2006 Share Posted April 14, 2006 This has been discussed for a bit, but now it can be confirmed. 04+ WRX springs (which are tapered in the rear) will fit 90-91 Legacies (which are also tapered in the rear). Here's what she looked like right after the wheel bearing project. Up in the air!!! The WRX springs are on the left, originals on the right: The WRX springs on the right, originals on the left: Here's what she looked like after the springs, MUCH better: And just today with the XT6 wheels and Yoko Avid H4's: Here are the corresponding part numbers: The springs themselves (04 WRX) 20330FE861 for the fronts 20380FE830 left rear 20380FE820 right rear Front top hats (04 WRX)- 20323FA000 Front upper rubber spring seats (04 WRX)- 20325AA000 The numbers following this are not confirmed to be NECESSARY, but I got them anyway. Front washers (04 WRX)- 20326AA000 Rear lower rubber spring seats (04 WRX)- 20375FC001 Rear upper rubber spring seats (91 Legacy)- 20375AA011 The car handles 150% better. Crisper turn-in, less body roll, more grip. The ride is somewhat stiff, but bearable. I highly recommend it!! Quote Link to comment Share on other sites More sharing options...
TROGDOR! Posted April 14, 2006 Share Posted April 14, 2006 I'm hoping to do this in my '94 wagon, once I find the right 90-91 strut components to retrofit. How would this work with a wagon though? I have no experience with Legacy suspensions yet, just the EA82 style- and on those, using the same springs on a wagon as on a sedan would result in a way off-balance ride height. Will these springs work fine in my wagon? Or do I need to get WRX wagon springs? Also, about how far would you say it lowered the car? Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted April 14, 2006 Author Share Posted April 14, 2006 If you want, I'll look up wagon WRX springs tomorrow. I really don't think it will matter. I don't know of any actual differences between wagon and sedan springs in the Legacy or WRX. I was actually going to measure the exact ride height of the car before and after, but I got impatient :-\. I'm inclined to say an inch. Enough to make a difference, but not anything drastic. Which was exactly what I was looking for. Quote Link to comment Share on other sites More sharing options...
jamal Posted April 14, 2006 Share Posted April 14, 2006 And 02-03 WRX springs fit 92-94 Legacies. I believe front upper perches are required as well. Also all 04-06 Impreza springs have the same fitment. If you want, I'll look up wagon WRX springs tomorrow. I really don't think it will matter. I don't know of any actual differences between wagon and sedan springs in the Legacy or WRX. The rates will be different. Especially in a Legacy. Legacy wagons have a much heavier rump roast than Imprezas. Stock rear Legacy wagons springs are something like 190 lb/in, whereas the Impreza wagon springs are only a bit stiffer than the sedan. One other thing I've heard is that the Impreza wagon has slightly taller springs. Also I would suggest getting Impreza wagon springs for a 1st gen legacy sedan. My 04 sedan springs are a little lower in the rear than I'd like, and the rates seem to be a bit better of a balance. Oh, and even if you put Impreza wagon springs on a Legacy wagon, it will ride a bit low in the rear. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted April 14, 2006 Share Posted April 14, 2006 Looks good Michael! Quote Link to comment Share on other sites More sharing options...
firstwagon Posted April 14, 2006 Share Posted April 14, 2006 If you want, I'll look up wagon WRX springs tomorrow. I really don't think it will matter. I don't know of any actual differences between wagon and sedan springs in the Legacy or WRX. I was actually going to measure the exact ride height of the car before and after, but I got impatient :-\. I'm inclined to say an inch. Enough to make a difference, but not anything drastic. Which was exactly what I was looking for. There is a difference, here's a great list someone put together.... http://bbs.legacycentral.org/viewtopic.php?t=2153 Quote Link to comment Share on other sites More sharing options...
TROGDOR! Posted April 14, 2006 Share Posted April 14, 2006 So, going by that chart... To maintain the best spring rates front and rear in my Legacy wagon, I should use WRX front springs and my stock rear springs? Interesting... Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted April 14, 2006 Author Share Posted April 14, 2006 By the way, here's the list prices for those parts: 20330FE861 $75.73 apiece 20380FE830 $75.73 20380FE820 $75.73 20323FA000 $13.68 apiece 20325AA001 $13.68 apiece 20326AA000 $3.87 apiece 20375FC001 $7.97 apiece 20375AA011 $13.68 apiece I didn't get a chance to look up the WRX wagon springs today, do you want me to look them up for you on Monday Steve? Quote Link to comment Share on other sites More sharing options...
TROGDOR! Posted April 15, 2006 Share Posted April 15, 2006 Well, going by the chart on the Legacy board, it looks like my stock rear springs are actually stiffer than the WRX ones. Can you shed any light on this? Quote Link to comment Share on other sites More sharing options...
jamal Posted April 15, 2006 Share Posted April 15, 2006 The back of the legacy wagon is heavy and it needs stiffer springs. Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted April 15, 2006 Author Share Posted April 15, 2006 It's possible, but look at my pics. The WRX springs are considerably shorter. So if you were to install WRX springs in the front and leave your stockers on the rear, your rump roast end would be up in the air. You couldn't possibly do anything worse for your handling. Quote Link to comment Share on other sites More sharing options...
