nighthawk Posted April 14, 2006 Share Posted April 14, 2006 So I pulled the oil pan off my Outback (98) after the engine sounded like a blender full of bolts and found large chunks of metal shavings (non aluminum, checked with a magnet), about 1/4 cup full. So I decided to put a 2.2 in rather than take the time and $ to find out if I have a boat anchor. Checked around and found the best deal for a 2.2 was a local JDM shop (JDM Enterprises in Philly). Got the motor home went thru changing wire harness from the 2.5 to the manifold of the 2.2. Everything hooked up except the wires from the EGR solonoid ( brown, left/ back, under manifold) and the purge control valve (black, right/ back, under the manifold). Question: Is there a solution? Do I need to go round up a US 2.2 manifold with the harness? Should I pull the heads from the 2.5, use the old Manifold and hope for the best? (I did this cause gas here is right around $3.00) Any suggestions???? Link to comment Share on other sites More sharing options...
the_bard Posted April 15, 2006 Share Posted April 15, 2006 Know what year the 2.2 was from? Link to comment Share on other sites More sharing options...
idosubaru Posted April 15, 2006 Share Posted April 15, 2006 the 2.2 doesn't have a purge control solenoid? the car should run fine without the EGR system installed. have you attempted to start it yet? Link to comment Share on other sites More sharing options...
nighthawk Posted April 15, 2006 Author Share Posted April 15, 2006 Don't know the year on the motor, it's a JDM. There wasn't any purge control on the japanese intake. Motor still on engine stand. Link to comment Share on other sites More sharing options...
idosubaru Posted April 15, 2006 Share Posted April 15, 2006 anyway to install the purge control solenoid from the 2.5 to the 2.2? Link to comment Share on other sites More sharing options...
