Meeky Moose Posted April 15, 2006 Share Posted April 15, 2006 its an 85' gl wagon carbed 2wd 5-speed.. body is almost mint except the rear cargo panels.. otherwise very nice inside an out.. but the guy told me it has a blown HG.. i said ok, took the car.. for $50 who wouldn't? its got parts for my 2wd dl.. anyways i put a battery in it pumped it 4 or 5 times (carbed) and it fired right up.. smooth as a bell. idles smoother than my 88 spfi wagon.. but its deffinitely blowing antifreeze out the exhaust.. clouds of it.. but i don't think its an hg.. cause it runs too damned smooth... no miss no loss in power (will roast the tires off it in 1st) no other symptoms at all... so i'm wondering if it just sucked an intake / carb base gasket... any ideas? Link to comment Share on other sites More sharing options...
manxsta Posted April 15, 2006 Share Posted April 15, 2006 Hi MM..if your getting water in the exhaust..then this means your should also be getting compression into the radiater...check for bubbles when the radiater is full..if you dont see any bubbles..i would remove the intake man..and check the gaskets..second guess would be to block any water pipe to the manifold..and see if the problems stops.also check your spark plugs first and this may tell you which side it is occuring on..the cleaner ones should be where the water is,correct me if im wrong guys ..... Link to comment Share on other sites More sharing options...
Frank B Posted April 15, 2006 Share Posted April 15, 2006 If the head is cracked on the exhaust valve side of the chamber, it wouldn't cause it to run bad. Most of the coolant, if not all, would go into the exhaust not the chamber. You'll never know untill you tear it down. Good score anyway. Link to comment Share on other sites More sharing options...
MilesFox Posted April 16, 2006 Share Posted April 16, 2006 replace the intake gaskets. see if that cures it. if so, you got a subaru. of not, then you know to look elsewhere, and you are only out the 6 bucks for the gaskets(which can be re-used!) Link to comment Share on other sites More sharing options...
86ruguy Posted April 16, 2006 Share Posted April 16, 2006 my 86 was blowin smoke like that and i used some block sealer. if you use it right it will seal the crack in the exhaust port and not smoke. i did this to mine about 30,000 miles ago and now i just check the oil every now and then. mine will roast em in fisrt and second:headbang: make sure that you use like copper seal or something like it and follow the directions on the bottle or it won't work. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 16, 2006 Share Posted April 16, 2006 My vote is intake manifold gakets - the aftermarket ones suck. Get em from the dealer, and follow the torque specs. Carb base gaskets can blow too - I would do that as well. GD Link to comment Share on other sites More sharing options...
