HATCHY Posted April 17, 2006 Share Posted April 17, 2006 do the cvs only click on turns? Link to comment Share on other sites More sharing options...
uncoolperson Posted April 18, 2006 Share Posted April 18, 2006 do the cvs only click on turns? i never got the turn click, instead i got some awsome clicks with the clutch and gas pedal up (there's a phrase for it, but i can't remember)... and that was a narly click too! Link to comment Share on other sites More sharing options...
scrap487 Posted April 18, 2006 Share Posted April 18, 2006 hatchy, dont spawn multiple threads for the same problem, and this is not offroad related. The search function is your friend, there are literally thousands of posts about bad axles and such on this board, dont want to create junk that gets in the way when people actually use the search function. Anyways, it sounds like a bad axle, get under your car inspect your boots, grab the axles and see if there is any kind of play in them when you twist it. move them in and out from the car and make sure the action is smooth, if it is rough like its dry its probably a bad axle. The other thing you could check are your ujoints in your driveshaft, they dont normally go bad and they are pretty tough, grab your axle and twist and move it around and check for play in the ujoints. If you dont have the anti rattle clips on your brakes that will cause a clicking type sound too, but it wont be constant, will disappear when you are braking. Link to comment Share on other sites More sharing options...
Subarian Posted April 18, 2006 Share Posted April 18, 2006 Are your castle nuts tight on the axles, and are your lug nuts tight. If either of those are loose, they can make a clicking sound (until the wheel comes off, then it's more of a thud and a grinding sound). Link to comment Share on other sites More sharing options...
Uberoo Posted April 19, 2006 Share Posted April 19, 2006 have you driven a car with the "thud and grinding sound" Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted April 19, 2006 Share Posted April 19, 2006 My rig has made all kinds of sounds over the years from squeeling wheel bearings to crunch clang bang BAM BAM! Especially when my front diff was going out, or my front CV fell apart and rattled around for two days before I found the prob:grin: . Link to comment Share on other sites More sharing options...
scrap487 Posted April 19, 2006 Share Posted April 19, 2006 have you driven a car with the "thud and grinding sound" Yes, yes I have. I have the "lightweight," "professional racing" backing plate to prove it Link to comment Share on other sites More sharing options...
