nicuso Posted April 19, 2006 Share Posted April 19, 2006 Having blown head gaskets repaired by dealer $$$ ohh 98 sub outback 99k found bt ex valve ? mistake not doing bottom end there is ofcourse $$$ issue Link to comment Share on other sites More sharing options...
NoahDL88 Posted April 19, 2006 Share Posted April 19, 2006 ? Complete sentences make it easier for us to help you Link to comment Share on other sites More sharing options...
idosubaru Posted April 19, 2006 Share Posted April 19, 2006 typically head gasket replacement is fine, fix the valves if any are damaged. if the car was abused, driven overheating extensively then there's no telling. Link to comment Share on other sites More sharing options...
nipper Posted April 19, 2006 Share Posted April 19, 2006 Its a good idea to change the oil. Ifd the blown HG was discovered like most, by over heating, the oil has may have been over heated too, and your bottom end will thank you. Are you saying burnt or bent exhaust valve? nipper Link to comment Share on other sites More sharing options...
nicuso Posted April 19, 2006 Author Share Posted April 19, 2006 that was burnt exh valve first time overheating, changed oil religiously had car since '01 @25k not abused, was going fishing easter morning for couple hrs. started running rough, pulled over very rough, decided to turn back got 1 mile noticed temp. 1/4 from top pulled over. flatbed truck driver said he hooked a subaru Link to comment Share on other sites More sharing options...
idosubaru Posted April 20, 2006 Share Posted April 20, 2006 sounds like you didn't ever overheat the thing really. new gaskets, have the heads tested by a machine shop and you're golden. get the engine oil changed at least twice as soon as possible like nipper said in case any coolant in the oil. Link to comment Share on other sites More sharing options...
otis Posted April 20, 2006 Share Posted April 20, 2006 nicuso said: Having blown head gaskets repaired by dealer $$$ohh 98 sub outback 99k found bt ex valve ? mistake not doing bottom end there is ofcourse $$$ issue can you tell me if I'm translating correctly... "I'm having a blown head gasket repaired by the dealer which is costing me a lot of money. Ohh my poor 98 subaru outback with 99k miles. I found bluetooth? I question the mistake of not doing bottom end? There is of course the money issue." Link to comment Share on other sites More sharing options...
frag Posted April 20, 2006 Share Posted April 20, 2006 otis said: can you tell me if I'm translating correctly... "I'm having a blown head gasket repaired by the dealer which is costing me a lot of money. Ohh my poor 98 subaru outback with 99k miles. I found bluetooth? I think that's "I found a burnt exhaust valve". What's the problem Otis? You can't read english? I question the mistake of not doing bottom end? There is of course the money issue." See above... Link to comment Share on other sites More sharing options...
