Its a good idea to change the oil. Ifd the blown HG was discovered like most, by over heating, the oil has may have been over heated too, and your bottom end will thank you.
Are you saying burnt or bent exhaust valve?
nipper
that was burnt exh valve
first time overheating, changed oil religiously
had car since '01 @25k
not abused, was going fishing easter morning for couple hrs.
started running rough, pulled over very rough, decided to turn back
got 1 mile noticed temp. 1/4 from top pulled over.
flatbed truck driver said he hooked a subaru
sounds like you didn't ever overheat the thing really. new gaskets, have the heads tested by a machine shop and you're golden.
get the engine oil changed at least twice as soon as possible like nipper said in case any coolant in the oil.
Having blown head gaskets repaired by dealer $$$
ohh 98 sub outback 99k
found bt ex valve
? mistake not doing bottom end
there is ofcourse $$$ issue
can you tell me if I'm translating correctly...
"I'm having a blown head gasket repaired by the dealer which is costing me a lot of money.
Ohh my poor 98 subaru outback with 99k miles.
I found bluetooth?
I question the mistake of not doing bottom end?
There is of course the money issue."
I found bluetooth? I think that's "I found a burnt exhaust valve". What's the problem Otis? You can't read english?:grin:
See above...
