Dumb DR Question
Was the dual range only a 4 speed? or was there a 5 speed D/R, besides the foriegn one.... :confused:
seems like a 5 speed would be much more enjoyable for highway driving :rolleyes:
definately both 4spd and 5spd... 4spd d/r's were in ea81's, 5spd in ea82 I think? someone correct if I'm wrong
yep - and if you look in the USRM under transmission secton - you can find info on converting from the 4-speed D/R to the 5-speed D/R - 5-speed is advantageous if you do highway driving, because it has overdrive - and pretty much the same ratios as the 4-speed
I thought the 4th gear was overdrive on the 4-speed?
Yup, according to Miles Fox, the 4spd D/R's 4th gear is overdrive:
http://www.economysuperstar.com/milesfox/subaru/service/ratio.htm
