jamesbissland Posted April 20, 2006 Share Posted April 20, 2006 Hi All Would anyone know if the bolt pattern on the EA81/82 flywheel is the same as the bolt pattern on the EJ series engine flywheel? Many thanks in advance, James Link to comment Share on other sites More sharing options...
calebz Posted April 20, 2006 Share Posted April 20, 2006 Nope Link to comment Share on other sites More sharing options...
jamesbissland Posted April 20, 2006 Author Share Posted April 20, 2006 Is that nope you dont know, or nope they aren't the same? Link to comment Share on other sites More sharing options...
86ruguy Posted April 20, 2006 Share Posted April 20, 2006 no they are not the same Link to comment Share on other sites More sharing options...
85Sub4WD Posted April 21, 2006 Share Posted April 21, 2006 EA81 and EA82 flywheels will interchange between each other, but they use an odd-space bolt pattern so they only go on in ONE way (because the timing marks are on it) - the EJ engines use an even-spaced bolt pattern - EA flywheels can be adapted tho to work on EJ engines - ask someone who has done the conversion, and they can tell you how Link to comment Share on other sites More sharing options...
ballitch Posted April 21, 2006 Share Posted April 21, 2006 no need to ask, just type in the words "ej swap" and you've got plenty of reading for the day. ~Josh~ Link to comment Share on other sites More sharing options...
