Went offroading today.. my oilpan isn't happy...
Andyjo
Oops...
I met up with 2 wranglers, one with a 3" lift & mudders, the other was pretty stock. Anyhow.. we did some pretty tough stuff, but it was all a good time, but i guess i managed to smash my oilpan pretty good... because when i got home i found this:
I'm going to see if i can take it off, and maybe TIG weld it up very carefully.. it's just a small pin-hole... is this a bad idea? or should i just go get a new one ($100 bucks.. blah)... Got the car very muddy, and the jeep guys were VERY impressed with it's capabilities.
Oh well.. i guess that's more modivation to finnish the bumper/skidplate, right? :rolleyes:
already posted in the market place :rolleyes:
Just here? Try NASIOC, I-club, RS25, local subaru shops, local junk yards, etc. etc.
I'm lucky in that I have a recycler AND a Pick + pull that I could walk into and get a oilpan no problemo for cheap...
my buddy had a return line welded onto his oil pan for when he added a turbo....so it can be done
I'm soooo protective of my oil pan, it can really keep my abilities limited, cause I'm worried about doing that to my oil pan, or worse :eek:
I run with out a skid plate with my lifted wagon. hehe, the only dent in it is from when I had to put a jack under it to pull my engine when I blew up my pilot bearing. There are tough oil pans. I'm pretty sure they are thin layer'd steel.
that looks similar to the damage i did to my pan awhile back,but i did mine on my driveway entrance.pulled in just a little to fast and then BANG...
of course now that i do have a skid-plate,i haven't had a need for it........(yet)
be careful of the threads on the EJ oil pans, they are tac welded in and don't like bashing. somehow and two of my pans have failed after being smashed/hing up on the drain plug, one at the beach and one in the mtns. my bigger problem is my gas tanks in my 91' legcacy, I lost over two gallons of capactiy in two days of high desert, no leaks as of yet though.
Magnet; ferrous material will stick. Aluminum is non-ferrous,no stick...
:burnout:
hey.. now why didn't i think of that.. i just took e-mag last semester :rolleyes: i was going with the 'let's see if it starts to rust' approch.. d'oh! :eek:
Well, they're not the same but, they can be made to work. I did this about two months ago and so did someone else on the board.
Pretty easy to mod to fit. The front mounting holes need to be widened. In the rear, you can lenghten the holes or add a small piece of metal to extend it. (I did the latter; other guy on the board took the "smarter, easier" route.)
Sorry to hear about the oilpan!
Andy.
Contact Aaron's Auto Wrecking here in Seattle. 1-800-541-7271. They're a Soob only J/Y. Ask for Tom or Lenny. Tell 'em who told you to call and where you heard about it. Might help with the price and shipping time. They ship btw. It'll be the right part, don't jimmy rig your imp.
EZ
