manxsta Posted April 22, 2006 Share Posted April 22, 2006 Here,s a simple question, are the ea 82 head gaskets the same for all ea82 engines? turbo- multi point- sigle point- and carbed??? Link to comment Share on other sites More sharing options...
calebz Posted April 22, 2006 Share Posted April 22, 2006 Yup, all the same. Link to comment Share on other sites More sharing options...
manxsta Posted April 22, 2006 Author Share Posted April 22, 2006 Yup, all the same. thankyou.... Link to comment Share on other sites More sharing options...
subiemech85 Posted April 24, 2006 Share Posted April 24, 2006 no, they aren't TURBO model uses a carbon sheet, and for the non-TURBO model a silicon-caoted asbestos calebz, wrong again!!! Link to comment Share on other sites More sharing options...
Snowman Posted April 24, 2006 Share Posted April 24, 2006 Yup, Subiemech is right. I do enough engine work that I like to keep an overhaul set on hand, and I always just buy the EA82T sets...if it works for the turbo engine, it'll work for the n/a engine. Link to comment Share on other sites More sharing options...
manxsta Posted April 24, 2006 Author Share Posted April 24, 2006 ill buy the turbo version..as that is what it will need..thanks guys... Link to comment Share on other sites More sharing options...
ballitch Posted April 25, 2006 Share Posted April 25, 2006 as long as the HG's are the same relative thickness you shouldnt have a problem. ~Josh~ Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted April 25, 2006 Share Posted April 25, 2006 Woh the headgaskets are different? So if I used a turbo gasket on a NA engine, they'd last longer? Link to comment Share on other sites More sharing options...
xoomer Posted April 25, 2006 Share Posted April 25, 2006 Fel-Pro Gasket is the same for both... Autozone has the Ea82t head gasket set for 139.99, in stock at most stores and for sure at the big Hub stores. or you can get the cheapo ROL for like $90 Special order. Link to comment Share on other sites More sharing options...
Gravityman Posted April 25, 2006 Share Posted April 25, 2006 Here if you are going to be ordering a head gasket for a turbo go for the GOLD! or i mean copper with rubber coating. I had the flatout group custom make me one for my ER27, only one like it in the world!!! They also have ones for EA81's and EA82's. The nice thing about these gaskets is you never need to replace them. You can keep using them every time you break into your engine where as all other gaskets you need to buy new ones. You could get the EA82 HG for about $94 and have it at your door steps in about a week. It only took them 2 weeks to one off custom make mine for the ER27. My Copper HG tread; http://www.ultimatesubaru.org/forum/showthread.php?t=40420 Flatout group catalog! http://www.flatoutgroup.com/orders/2006FlatoutGasketsPDFECatalog.PDF Link to comment Share on other sites More sharing options...
