How do i remove the MPFI Intake?
I have a motor that i bought. the guy before me tried to remove the intake and he broke 2 of the bolts. Now that i have it, i cant remove the intake.
There are only 6 bolts right?
Any suggestions welcome
Thanks in advance
Gannon
Hi , basically the only way your will have any chance of removing it is to pump the bolts and holes full of wd 40 or penetrating oil , let it soak and then pry it up with a lever between the intake and the engine(with care but you will need to use some force to start it moving....once it moves up a little,use more wd..and send it back down to the head..and repaet this until it eventually comes free..heat may be of some help alternativly..but i would opt against this method,patience will be your key..corrosion sucks..cheers
There is no such thing as a stupid question,.. but yes i did remove the EGR.
As far as penetrating fluid goes, ive been told to find an alternative to wd40,.. PB Blaster? INOX? any others
Thanks Guys
Gannon
