E82 engine with 4 injectors with turbo
Hi I need to know if I can use this engine (E82 engine with 4 injectors with turbo) in conjuntion with a 3 speed automatic transmission which currently is running with a 1600 (Israel) engine and will there be problems using the E82 engine in this configuration.
The E82 engine with 4 injectors with turbo is also the RX Turbo 4 wheel drive engine.
Also if there is the computer and wiring for this engine as in Israel there is no computer and wiring for this engine.
the engine may, or may not fit - is the starter in the top-center, or to the left of the top of the bellhousing? (looking as if you are sitting in the driver's seat, facing forward) If it is the latter (left of top), it should bolt up (I think all 3-speed autos use the compatible configuration) - yes, you will need the wiring harness/computer from the turbo car - there's really no way around it, there are some aftermarket FI systems, but it would be easier to install a stock Subaru system
good luck
mmm, without the wiring and cpu(computer) you should not even start the conversion,as it is not a simple job,ideally your should have a complete turbo vehicle sitting beside you,as a donor, when you start..
good luck.:)
