WJM Posted October 24, 2003 Share Posted October 24, 2003 Ok, after a nice 110 MPH run, WOT, for aobut 3 miles, I come to a stop, ruff idle, and its got aobut 1/3 power. Its getting fuel and fire. I have no way to see if its getting fire at the right time tho...and no way to check compression. Its oil and coolant leves and pressures are normal, temps too. So, what it the problem? Any guesses? Seems like 1 and 3 are not contributing very much, btw... Link to comment Share on other sites More sharing options...
Dr. RX Posted October 24, 2003 Share Posted October 24, 2003 Hard to say without being there, but Id say that you blew a vacuum line somewhere. Link to comment Share on other sites More sharing options...
calebz Posted October 24, 2003 Share Posted October 24, 2003 pull your plug wires one by one and see if it makes a difference. If you pull one and the idle doesn't change, chances are that cylinder isn't firing.. but, like corky said, you probably blew a vacuum line Link to comment Share on other sites More sharing options...
WJM Posted October 24, 2003 Author Share Posted October 24, 2003 Thanks Corky, I'll check that. calebz: I pulled each plug wire one by one, each cylinder makes a difference. I also pilled Fuel injector plugs too...makes same diff as plug wires. So, vac line search. Anyone else? Link to comment Share on other sites More sharing options...
Toyofast Posted October 25, 2003 Share Posted October 25, 2003 Plugs still good? Are your plug wires arching? Link to comment Share on other sites More sharing options...
WJM Posted October 25, 2003 Author Share Posted October 25, 2003 plugs are new now. I put NGKs in, and new wires. Good strong arc'age. Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 25, 2003 Share Posted October 25, 2003 Perhaps your fuel injectors weren't contributing enough fuel in cylinders 1 and/or 3 causing the pistons rings to overheat. I hope that's not true and I'm probably WAY off but that is what happened to project RX at the Subespeed site. I believe he was making a highway run as well. Good luck! Link to comment Share on other sites More sharing options...
PHATBRAT Posted October 25, 2003 Share Posted October 25, 2003 My vote also goes to a vacuum line. If not that then try a new fuel filter. Link to comment Share on other sites More sharing options...
SuperRallyRoo Posted October 25, 2003 Share Posted October 25, 2003 I drove my volvo from seattle to oregon at a non stop 80mph... Its a 4spd and thats like REALLY fast for that car. When i slowed down it would not rev below 3000rpm and had about 1/2 power. It was a vacuum line and the air intake fell off somewhere along the way. Link to comment Share on other sites More sharing options...
WJM Posted October 25, 2003 Author Share Posted October 25, 2003 I tihnk that maybe I have lost compression on cyl number one or three....the subspeed dude was cruising. I was at WOT. lol So myabe I had the same problem, but it appeared more suddenly, i would not doubt there being trash in the FI system, the car was poorly maintained. I just installed a new fuel filter. Maybe a burned valve? Link to comment Share on other sites More sharing options...
Hondasucks Posted October 25, 2003 Share Posted October 25, 2003 I'd do a compression check if I were you, that would aid the diagnosis. I dunno about back there, but out here Schucks has a tune-up kit that comes with a timing light, compression tester, and like 2 other tools for like $40 bucks. Link to comment Share on other sites More sharing options...
Turbone Posted October 25, 2003 Share Posted October 25, 2003 WOT for 3mi doesnt sound like much but, I bet that turbo got plenty hot! You might have fried the cat, if you still have one. Rob Link to comment Share on other sites More sharing options...
WJM Posted October 25, 2003 Author Share Posted October 25, 2003 no cats to fry! But those P/S lines look pretty cooked... Link to comment Share on other sites More sharing options...
MilesFox Posted October 25, 2003 Share Posted October 25, 2003 my car dropped a valve seat, i believe. did your heads have cracks between the valves? mine had trouble after an 8000 rpm rev. (i know that wasnt good, but i just so happened to be at a high school parking lot with weak oil burning rice wannabes!) Link to comment Share on other sites More sharing options...
WJM Posted October 25, 2003 Author Share Posted October 25, 2003 i dont have the engine apart yet, LOL. I am going to compression test each cyl soon, like, in 20 mins. Link to comment Share on other sites More sharing options...
WJM Posted October 25, 2003 Author Share Posted October 25, 2003 Cylinder Number Three, exhaust valve seat. Valve stuck open. The GL-10 is in the middle of the FT4WD conversion, shift linkages and center driveshaft support still being worked out...so, I have no transportation....although the RX is still driveable... Link to comment Share on other sites More sharing options...
