hatchsub Posted April 29, 2006 Share Posted April 29, 2006 Hey i know that at least on the later hitachi carbed EA81's there were dual duty solenoids mounted on the intake manifold but on the carter-weber carb there was only one mounted on the carb itself. I swapped intakes and my car runs great with the two barrel but i dont have a duty solenoid cause i would only need one. So my ECS light comes on because of this. Anyone know if there was a year when there was only one duty solenoid mounted on the intake and if so...anyone got a good one they want to get rid of Thanks alot guys. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 30, 2006 Share Posted April 30, 2006 Hitachi and Carter/Weber feedback systems are not compatible. The ECU is different among other things. Just rip it all off and use a non-feedback carb. Sounds like maybe you did already? Pull the ECU out - it's under the drivers side kick panel. That will extinguish your ECS light.... forever. GD Quote Link to comment Share on other sites More sharing options...
