Myxalplyx Posted October 25, 2003 Share Posted October 25, 2003 I did a search and couldn't find any information on this site pertaining to my question. So here it goes.... Is there any reason why the turbocharged people here haven't considered using an air/water intercooler like that from the Legacys? I'm thinking that maybe the Legacy air/water intercoolers and other parts would be able to fit in some of the 1.8ltr turbos engine bays where the spare tire would be. Just curious! I think I read of one mention of it here from a guy named 'Adam N.D.J.' thinking about using it but besides that, I couldn't find much. Here's an interesting how-to page that I found someone linking to from another site. Fitting Legacy Air-Water Intercooler to WRX Link to comment Share on other sites More sharing options...
josh long Posted October 25, 2003 Share Posted October 25, 2003 I did this set up on a buddies rally car. we ran the water thru the ac condensor with a boat bilge pump. Worked great! Link to comment Share on other sites More sharing options...
Dr. RX Posted October 26, 2003 Share Posted October 26, 2003 One reason is that it is much simpler to install and air to air I/C. Installing a water to air I/C requires adding an elecrtic water pump, additiona tubing and an addition radiator (simpler to the condensor of the A/C system). Far more complex the just adding the air to air I/C. And unless you are in an area that has High temperatures, the water to air is not any better then the air to air. Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted October 26, 2003 Share Posted October 26, 2003 Unless you add some good stuff to the water like dry ice!! Yes, I was talking of doing this. A buddy of mine has one on his Legacy and it rocks! So I figured if it's good for the Leg, then it should be good for me. It is a little more complicated than and air/air, so thats why most people don't use em, with the a/a all you have to do is put it on and cut a hole in the hood, good to go. Me on the other hand, I've got an 84 Turbo, and want to keep it looking as stock as possible, no matter whot I do to it undernieth the hood. If I have a big ol hole and scoop in the hood, too many people will get the idea that I actually have power and stuff, (cough cough). Link to comment Share on other sites More sharing options...
baccaruda Posted October 26, 2003 Share Posted October 26, 2003 i've heard that water to air ICs are more efficient at cooling UNTIL they get heat soaked, and then they take longer to cool down than air to air ICs?? Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 26, 2003 Author Share Posted October 26, 2003 Quote Originally posted by Adam N.D.J. Me on the other hand, I've got an 84 Turbo, and want to keep it looking as stock as possible, no matter whot I do to it undernieth the hood. If I have a big ol hole and scoop in the hood, too many people will get the idea that I actually have power and stuff, (cough cough). This is why I asked. For those people who like keeping the stock look but have some extra power underneath. I thought it may be more complicated trying to fab a hood scoop at the proper location then by using an air/water intercooler setup that's already out there for the Subaru. It would be nice to see someone that has already done this though and their take on the results. Link to comment Share on other sites More sharing options...
WJM Posted October 26, 2003 Share Posted October 26, 2003 I was thinking more on the lines of.....Liquid Nitrogen.... Now that should certinly keep the intake air charge not just cool, but COLD. *shiver* Link to comment Share on other sites More sharing options...
