ea82 5spd d/r 4wd trannys and EJ22s?
Mr. Carb
if you are going to wheel with it you will probably want the d/r tranny....however, if it is in a street rig the EJ trannies are definately stronger. make sure if you do swap the trans that you swap the rear diff with it.
