May 1, 200620 yr well me and my smart a$$ mechanic brain just said "12 volts, duh" and i doubt it being different.
May 1, 200620 yr Author no, your wrong, you hook 12 volts up and it will run but loud, if it works properly it dont make noise, DUH well me and my smart a$$ mechanic brain just said "12 volts, duh" and i doubt it being different.
May 1, 200620 yr sorry didn't mean to sound snobby, just a little bit tired. so before i hit the wall, i will hit the sack
May 1, 200620 yr Author ahh its ok, i just dont think it is 12 volts, but it could be sorry didn't mean to sound snobby, just a little bit tired. so before i hit the wall, i will hit the sack
May 1, 200620 yr Pretty sure its 12v. Both our EA81's have loud fuel pumps (the rear one, not the one under the hood) Once the car is running you can't hear them though. I wouldn't think they'd put a volt regulator in for the pump, doesn't seem sensible.
May 1, 200620 yr Author the one under the hood??? Pretty sure its 12v. Both our EA81's have loud fuel pumps (the rear one, not the one under the hood) Once the car is running you can't hear them though. I wouldn't think they'd put a volt regulator in for the pump, doesn't seem sensible.
May 1, 200620 yr It's 12v - I've wired them plenty of times for one, and for another it would be silly to use lower voltage for something like that as it's less effecient. Early soobs had the pump under the hood - pre-82 were all like that. They are LOUD - so loud I can "feel" the one in my Brat runnning. On the Brat the pump is much closer to the drivers seat under the cab than the rest of the models. I can hear the one on my 86 sedan too - quite loud. Both are stock pumps. GD
May 1, 200620 yr Author so is there one under the hood or.. not, does yours run normally, or did you rig a switch to it? mine dont run, only 3 volts are at the pump, and i thought there was a bad relay but none that i find are bad, so.... i need help, whats wrong with this? It's 12v - I've wired them plenty of times for one, and for another it would be silly to use lower voltage for something like that as it's less effecient. Early soobs had the pump under the hood - pre-82 were all like that. They are LOUD - so loud I can "feel" the one in my Brat runnning. On the Brat the pump is much closer to the drivers seat under the cab than the rest of the models. I can hear the one on my 86 sedan too - quite loud. Both are stock pumps. GD
May 1, 200620 yr Early soobs had the pump under the hood - pre-82 were all like that. GD Hmm, weird. My brothers 83 wagon has a pump by the tank and one under the hood. The one under the hood ticks for a bit then slows down and only ticks every so offen. But that's how it is suppose to work. The one near the tank just runs all the time. You may have bad wiring which is only giving you a very low volt reading. Or it could be a relay. Best thing to do is get a relay off another EA81 and try it to see if that works. Just the usual troubleshooting stuff.
May 1, 200620 yr Author i been kind of doin that all day, i even swoped out wiring harness and got new relays, where is the one under the hood your talkin bout? Hmm, weird. My brothers 83 wagon has a pump by the tank and one under the hood. The one under the hood ticks for a bit then slows down and only ticks every so offen. But that's how it is suppose to work. The one near the tank just runs all the time. You may have bad wiring which is only giving you a very low volt reading. Or it could be a relay. Best thing to do is get a relay off another EA81 and try it to see if that works. Just the usual troubleshooting stuff.
May 1, 200620 yr My brothers 83 wagon has a pump by the tank and one under the hood. That's surely different - never seen anything like that here in the states. Totally bizzare. GD
May 1, 200620 yr i been kind of doin that all day, i even swoped out wiring harness and got new relays, where is the one under the hood your talkin bout? You don't have one under the hood - pretty much guarantee it. Only 80/81 Gen II's have the under-hood pump. Have you checked the FPCU? GD
May 1, 200620 yr Author so there isnt one under the hood? i dont think models would change that much, there is the one by the gas tank, like you were saying ealier, but nothin else that i can find That's surely different - never seen anything like that here in the states. Totally bizzare. GD
May 1, 200620 yr Author jsut to make sure, what does the FPCU look like and where,? is it under the kick panel and blue? You don't have one under the hood - pretty much guarantee it. Only 80/81 Gen II's have the under-hood pump. Have you checked the FPCU? GD
May 1, 200620 yr It's blue? Do you have the feedback carb?!? Yuckies. Anyway yes - it's attached to the bolt for the hood release cable - right above it. GD
May 1, 200620 yr Author ok, yea i pulled the blue box out of my parts car, and still no luck, i hace a webber carb, It's blue? Do you have the feedback carb?!? Yuckies. Anyway yes - it's attached to the bolt for the hood release cable - right above it. GD
May 1, 200620 yr The under hood fuel pump is up by the windscreen (windsheild) wiper motor. But it sounds like you don't have it. I have noticed these sorts of thing between Aus models and US models... Good luck with your problem, sorry I can't be of more use.
May 1, 200620 yr If you only have 3v at the pump, then the wires leading to it are bad somewhere along the circuit. Try running new wires back to the FP.
May 1, 200620 yr Author but i have swoped out wiring harnesses, there, so wouldnt that be the same? If you only have 3v at the pump, then the wires leading to it are bad somewhere along the circuit. Try running new wires back to the FP.
May 1, 200620 yr As it was stated about the voltage at the pump the voltage is supposed to be 12 volts. It sounds like there may be a problem with the fuel pump control unit which is under the far left side of the dash on a American version.
May 1, 200620 yr Author the pump control unit is that a blue box? As it was stated about the voltage at the pump the voltage is supposed to be 12 volts. It sounds like there may be a problem with the fuel pump control unit which is under the far left side of the dash on a American version.
