help with 91 loyale
I have a 91 loyale I'm working on for a buddy. When I received the car it didn't even run, but by replacing a few igintion related parts it's now running good. However, I can't figure out why the drivers side door controls do not work. they did when I got the car last week....it was the only thing that DID work!?!?!
I cannot find the fuse or relay for this door. The fuse box lists #12 as the fuse for the windows, but that has no effect and is intact.
All other doors and their window controls work fine...even with the #12 fuse out.
Questions...WHERE is the correct fuse? Any thoughts why it worked last week and not now?
I replaced the distrubutor, wires, plugs...nothing to do with the door.
help!!
Those switches can get dirty and quit working. If no bad fuses, take the door panel off - not too hard on a Loyale. Make sure the window control panel is plugged in tight. If that's ok, then you can take the window control panel out, take it apart and clean it with a pencil eraser. Do it on a large clear surface, because there are some little parts in there that can go rolling off into oblivion.
