nipper Posted May 8, 2006 Share Posted May 8, 2006 The tstat rose again, but came back down pretty quick. Air was blowing hot, and the cooling fans worked. The events seem to be bubbles, I was driving on gravel roads a bit before this most recent event, so maybe that stirred some loose? Should i take the car back in and make them bleed the coolant system? i agree with above. you have a air bubble in the system. Usually with a bad HG you have poor or no heat, and the temp gauge would climb higher then your seeing. nipper Link to comment Share on other sites More sharing options...
eagleb Posted April 3, 2007 Author Share Posted April 3, 2007 Just in case anybody is experiencing similar problems, I did end up having the head gaskets replaced. I never overheated the engine, but there was definitely exhaust making its way into the coolant, forming a bubble at the tstat, then passing. I took the car to superior import repair, and a hydrocarbon test showed HCs in the cooling system. It was what I expected in the end. On a brighter note, since the heads were off, I had the valves cleaned, and have not had the shuddering or cylinder 4 misfire code since. I don't know if the valve cleaning or the TransX additive are what took away the shudder, but I'm hoping it was the valve cleaning. Only time will tell. Link to comment Share on other sites More sharing options...
