Need location of purge tank seliniod
The new,1990,Legacy is throwing 2 codes. knock sensor and purge valve. I found the knock sensor under the throttle body but cannot find the purge tank selinoid. Anyone help me out? I did some yarding today for it and got a rear hatch for $10.00 today. I also found a few knock sensors but all were cracked. I'm sure those are no good. Thanks all!! Mark
It is on the underside of the intake manifold, on the right side of the car. You should have a small vaccume hose going to the throttle body. Follow that away from the TB, and you will find the Purge valve.
Thanks, I'll go loking for it today.
