skeet Posted October 26, 2003 Share Posted October 26, 2003 I'm at my bosses, the computer and connection are so slow my searches are timing out, so I am making a new thread. VIVA LA ANNOYING WEBER THREADS!!!! So, the power steering chicken is in the way of my choke nugget. I really don't want to flip the whole carb and run the throttle cable around the world.... Is a manual choke that bad? Do I have any other options? Link to comment Share on other sites More sharing options...
skeet Posted October 26, 2003 Author Share Posted October 26, 2003 And also... Assuming I decide to spin 180.... Is the throttle cable long enough or do I have to extend it? How much crap is there involved in that? Link to comment Share on other sites More sharing options...
Tom63050 Posted October 26, 2003 Share Posted October 26, 2003 There is a conversion kit available from http://www.piercemanifolds.com that converts either electric or water choke to manual choke. Look under "Linkage and Fuel Components". Link to comment Share on other sites More sharing options...
skeet Posted October 26, 2003 Author Share Posted October 26, 2003 *smashes ****ty computer* I FINALLY got the USMB repair manual to load and its all red Xs!!!. Link to comment Share on other sites More sharing options...
skeet Posted October 26, 2003 Author Share Posted October 26, 2003 Oh I don't really need a kit to do the manual conversion. I can piece all that together. I just don't want to have to do it if there is another way. But it looks like that is going to be the way to go, I don't really want to do the 180 spin thing. Link to comment Share on other sites More sharing options...
skeet Posted October 26, 2003 Author Share Posted October 26, 2003 Will someone please post a pic of an engine with a 180 offset Weber? I need to see how you routed the throttle cable. I'm having issues. BUT SHE RUNS!!!!! Link to comment Share on other sites More sharing options...
skeet Posted October 26, 2003 Author Share Posted October 26, 2003 Ok, so I am looking at the carb from standing in front of the car ... You ran the cable down the right side, under the throttle, under the little harness, and then looped it up and back? Link to comment Share on other sites More sharing options...
skeet Posted October 27, 2003 Author Share Posted October 27, 2003 bizump Link to comment Share on other sites More sharing options...
JonOfScio Posted October 27, 2003 Share Posted October 27, 2003 or, you could always remove power steering... but hey, in a wagon, yeah, it's good to have. But I definately don't need it in my hatch, so that's why I've never bothered adding it. Link to comment Share on other sites More sharing options...
skeet Posted October 27, 2003 Author Share Posted October 27, 2003 I'm a huge fan of power steering. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted October 27, 2003 Share Posted October 27, 2003 I have a 180 degree turned carb.... I put the throttle mount in some other holes in the intake manifold... I actually had to shorten the cable as it comes up from the bottom of the carb, then loops around the throttleplate thing along the front up to the top. I used one of the plates where you can just pass a cable through and tighten a screw down on the cable to keep it in there. I tried keeping the cable long but it wouldnt work, it had to be bent too much and it bound up. Sorry I dont have any pics of it Link to comment Share on other sites More sharing options...
Svengouli7 Posted October 28, 2003 Share Posted October 28, 2003 Mine is 180*. I did not shorten my cable, and that has not been a problem. I picked up a choke kit at napa- the "nugget" in the kit as a cover did not fit well, went the turned route. Noah88DL installed his w/ choke, head on- he just beat the PS rez till there was room. If that was me, I woulda caused more problems for myself and still had to turn the carb- but it has been done. Any leaks Noah??? From what I understand, installing a Weber either way we are forced to in our cars isn't ideal, and can lead to hang up of the float on hard turns, hills. I have suffered fuel starvation in moments like that. I've read the float pin/hinge should sit parallel to the firewall, and in the most forward position if possible. Either way, the coolant passage was barely covered w/ both Cameron's plates and kit ones, and match up to the intake once "flipped" wasn't ideal (dremel?) I used the brass del nipple in the port to support a bit of aluminum cut to shape, countersunk, then covered w/ quicksteel. No one stepped forward when I was dealing w/it as to whether there was any real reason the secondary should not be most forward spot... So, its been runnin okay since then, jetting is okedoke but Im sure could get better. If you take the top off yours, pls post your jet sizes (air correctors n mains, idles if you look) good luck Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted October 28, 2003 Share Posted October 28, 2003 I run the redline/weber 2 piece adapter and backwards it actually fits REALLY well.... Link to comment Share on other sites More sharing options...
baccaruda Posted October 28, 2003 Share Posted October 28, 2003 skeet, i have an XT power steering pump left over from my engine switcheroo. its tank has a lower clearance. want it? Link to comment Share on other sites More sharing options...
