mtnpat Posted May 4, 2006 Share Posted May 4, 2006 Getting ready to change my plugs to try and cure the dreaded Subaru pinging, and was wondering how many steps colder I should go? I don't know what is in there now, but just for arguements sake let's say they are BKR5E-11. Should I try BKR6E-11 or BKR7E-11? Try one or two steps colder to try and cure pinging? THANKS Quote Link to comment Share on other sites More sharing options...
cookie Posted May 4, 2006 Share Posted May 4, 2006 I was taught to go only one heat range at a time. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 4, 2006 Share Posted May 4, 2006 yes only one heat range at a time, especially if the pinging seems to be affected by air temperiture. That means its very subtle. nipper Quote Link to comment Share on other sites More sharing options...
2X2KOB Posted May 4, 2006 Share Posted May 4, 2006 These are NGK numbers? And a higher number is colder? /thanks... Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted May 4, 2006 Share Posted May 4, 2006 What year and model car???? I really would highly recommend against going one step colder plug on a relatively stock engine. Your gas mileage will be crap, the engine won't run as good, etc. If you truly think your car is "pinging" run higher octane fuel. If that makes no difference, then I don't think you're hearing any pinging. Can you describe what you are hearing/experiencing with some detail. Quote Link to comment Share on other sites More sharing options...
blitz Posted May 4, 2006 Share Posted May 4, 2006 What Josh said. An over-heated plug can cause pinging, but a correct temp one won't. Should be a BKR6 IIRC. If you towed a heavy trailer on the freeway at WOT or near WOT, that would elevate your plug temp and likely force you to step down a range. If you supercharged or turbocharged your motor and raced with it, that would elevate your plug temp and force you to step down a heat range or two to compensate. Going colder than the stock heat range, on a stock motor, being driven normally will likely result in fouling. **** ******! Quote Link to comment Share on other sites More sharing options...
cookie Posted May 4, 2006 Share Posted May 4, 2006 But what else can you test for 10 bucks that might fix it? If you pull your current plug and it is white and shows evidence of pinging it can't hurt to go down a range. Quote Link to comment Share on other sites More sharing options...
fastwgn286 Posted May 5, 2006 Share Posted May 5, 2006 you know, come to think of it, i'm going to have this question. which plugs should i use in my 97 outback? it just hit 120k, which means servicing! which plugs should i use? any suggestions? what do you guys/gals have? -yet another scooby nooby Quote Link to comment Share on other sites More sharing options...
nipper Posted May 5, 2006 Share Posted May 5, 2006 I think you are going to hear Original Equipment plugs, which i think is NGK nipper Quote Link to comment Share on other sites More sharing options...
cookie Posted May 5, 2006 Share Posted May 5, 2006 Everybody advised me to go NGK when I did mine at 120,000. I have been very happy with the fact that it works fine. No need to reinvent the wheel and if you don't have problems stay with what works. After the price of the plugs for my BMW which are about a car payment I was thrilled to get good stuff for a tenner. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 5, 2006 Share Posted May 5, 2006 But what else can you test for 10 bucks that might fix it? Seafoam ;^) Carl Quote Link to comment Share on other sites More sharing options...
brus brother Posted May 5, 2006 Share Posted May 5, 2006 Been there, done that, bought the t-shirt and still pinged away. Seafoam ;^) Carl Quote Link to comment Share on other sites More sharing options...
cookie Posted May 5, 2006 Share Posted May 5, 2006 Seafoam could help if a a car pinged becuse of carbon deposits. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 5, 2006 Share Posted May 5, 2006 edit; see this; http://www.ultimatesubaru.org/forum/showthread.php?t=57632 Didn't someone just fix pinging by changing their coilpack? Yeah, it was weird but it worked. Carl Quote Link to comment Share on other sites More sharing options...
Setright Posted May 6, 2006 Share Posted May 6, 2006 NGK heat range 6 will be good. You might just have fouled/worn plugs in there now. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 6, 2006 Share Posted May 6, 2006 edit; see this; http://www.ultimatesubaru.org/forum/showthread.php?t=57632 Didn't someone just fix pinging by changing their coilpack? Yeah, it was weird but it worked. Carl i feel better that im not the only one to find it odd. Unless the hotter coil cleared the fouled plugs and that stoped the pinging. nipper Quote Link to comment Share on other sites More sharing options...
