I'd like to check the runout on my brake rotors before I do my brake job. Does anyone have a recommendation on a dial indicator, or is this something you usually have a shop do? Thanks all.
Dan
So what I'm understanding is that when changing my brakes, if I'm not feeling any vibration under braking, then the only reason I would need to change the rotors is if they're too thin??
Dan
  1 Lucky Texan said:
I agree with cookie. Unless there was an extreme issue with torque when the rotors were installed, any 'warp' feeling is more likely to actually be surface changes in the rotor alloy itself. better to get new rotors usually.
check www.stoptech.com the tehcnical white paper on the Myth of warped Rotors (IIRC)
Carl
