NewDriverOlderRide Posted May 10, 2006 Share Posted May 10, 2006 Ok, On my 93 Loyale 5spd. SW pushbutton 4WD, it is dripping gas from some sort of "metal diaphragm"? It is coming from about 1 ft in front of the right rear wheel, near the fuel pump. An suggestions? I can get pics tomorrow if it will help. Thanks Tyler Link to comment Share on other sites More sharing options...
subiemech85 Posted May 10, 2006 Share Posted May 10, 2006 some type of pulse preventer, vibration dampner should be able to bypass it Link to comment Share on other sites More sharing options...
Chris Rogers Posted May 10, 2006 Share Posted May 10, 2006 some type of pulse preventer, vibration dampner should be able to bypass it vibration damper. find another one. btw fuel here in Oz is 1.34/litre (4.625 L = 1 gallon) so we notice fuel drops more.. Link to comment Share on other sites More sharing options...
Gl-boost Posted May 10, 2006 Share Posted May 10, 2006 Mine leaks from ther also, but its a very mild drip. I have a leaking gas tank so that is my main concern right now. I just have to find the time to drop it, and well since the rear had to be droped also just to take out the dam tank. It sounds like a good time to me . I just hope all goes well, and nothig breaks such as bolts. Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted May 10, 2006 Share Posted May 10, 2006 When you pull that tank spray the bolts&nuts down with good dose of pb blaster.Makes coming apart and putting back together much easier. Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted May 11, 2006 Author Share Posted May 11, 2006 Ok thanks guys. Link to comment Share on other sites More sharing options...
scoobyroo86 Posted May 11, 2006 Share Posted May 11, 2006 i thought my gas leak was soely from the fuel lines on my brat but today i checked underneath and realized i need a new tank, anyone know where to get one? Link to comment Share on other sites More sharing options...
ShawnW Posted May 11, 2006 Share Posted May 11, 2006 Probably best to get yours repaired by a shop that does tank reseals. Radiator repair shops do em quite often. Link to comment Share on other sites More sharing options...
Gl-boost Posted May 11, 2006 Share Posted May 11, 2006 ok then, I didn't mean to steal your thread but thanks for the help also. Link to comment Share on other sites More sharing options...
Syonyk Posted May 11, 2006 Share Posted May 11, 2006 Ok, On my 93 Loyale 5spd. SW pushbutton 4WD, it is dripping gas from some sort of "metal diaphragm"? It is coming from about 1 ft in front of the right rear wheel, near the fuel pump. An suggestions? I can get pics tomorrow if it will help. Thanks Tyler It's the pulsation damper on the fuel pump. I know exactly what you're talking about - it's the reason I got my GL for $350. I replaced the entire fuel pump assembly because I couldn't figure out how to get the damper off, and the pump was starting to make some interesting noises anyway. You could probably eliminate it if you wanted. It's on the high pressure side of the fuel system, so be careful when you take the pump out - it sprays. You can drop the fuel pump tray, disconnect the wires & fuel lines, and work on it out in the open if you want. Be sure to plug the line coming out of the fuel tank - it's big, and dumps a lot of gas down your arm. Pliers on that will help reduce the leakage until you can cap/plug it. -=Russ=- Link to comment Share on other sites More sharing options...
scoobyroo86 Posted May 11, 2006 Share Posted May 11, 2006 Probably best to get yours repaired by a shop that does tank reseals. Radiator repair shops do em quite often. about how much does that run, the only tank ive found on the web was over $300! Link to comment Share on other sites More sharing options...
