How much torque?
Basically, what I need is something to reverse the direction of power, slow the speed down, and split it 90º with a differential. I have an engine and automatic transmission, and I want to hook the output of the auto to the input of the tranny, run it in low range, in reverse, and take power off the axle stubs. The tranny will be locked in reverse, under a plate, with no linkage connected to it.
Maybe I should just throw this thing together and see if it holds- it'll see some pretty decent stress on it, hoepfully the wheels will slip before it reaches the breaking point if I remember not to overload it. If/when it breaks, it'll be replaced by a Ford 9" diff with 7.30 gears, flipped upside down.
