pearlm30 Posted May 11, 2006 Share Posted May 11, 2006 I found a 95 legacy LSI with a adjustable driver seat. I am wondering if it will direct bolt on to MY 93 Impreza. Thanks for the help Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted May 11, 2006 Share Posted May 11, 2006 I don't think it will be too hard to make it fit.Might be as simple as dropping it in or elongating one of the bolt holes or something like that.Either way it can be done,but I am no expert.I just know if you want it bad enough you can do it. Quote Link to comment Share on other sites More sharing options...
Gnuman Posted May 11, 2006 Share Posted May 11, 2006 You don't even have to want it real bad. . . The seats are interchangable. . . Quote Link to comment Share on other sites More sharing options...
northguy Posted May 11, 2006 Share Posted May 11, 2006 If not, check the USRM for ideas on seat brackets. Quote Link to comment Share on other sites More sharing options...
dmanaenk Posted May 11, 2006 Share Posted May 11, 2006 I have switched the other way - 00' RS seats into 96' legacy. Was a direct bolt-on. Make sure you grab plastic covers that go onto rails in the back. Legacy covers did not fit impreza seat, so I suppose coverse is true also. Quote Link to comment Share on other sites More sharing options...
