can anyone help damsel in distress!!!
:confused: I have an 1988 subaru justy DL and the dash lights just stopped working on me. I have checked all the fuses and they all seem to be good. Could it be the dimmer switch ? Any one with any information for me i would sure appreciate it. Donna:-\
Welcome!
Yes, it could be, but also check in the Engine compartment, there is a huge cable with a lot of wires inside, that goes from and to the engine, it maybe is loose in its connectors... (Female and Male) so it may is doing False Contact...
Check it and give us Feedback about...
Good Luck! :)
You might need to get the screw driver out, pull some plastic off the dash around the instrument cluster and dimmer switch and check all the connections onto the cluster and switches. Basically just pull them off, make sure the wires aren't hanging out and plug them back in.
It can get very annoying chassing down these problems, but if you persist, you'll get there (we hope.)
...1988 subaru justy DL and the dash lights just stopped working
Hey, Hey, Donna; *couldn't resist
Welcome too the site, were almost neighbors ;) Not very often a new contact from the dry side of the mountains.
As for issues.... sorry... no idea. Someone will get you going in the right direction.
good luck
