subie2 Posted May 12, 2006 Share Posted May 12, 2006 has anyone heard of this? i just bought an 04 outback and after it rained at night, the next morning i heard alot of water that sounded as if it was coming from under the car on the driver's side. when i brought the car to a stop and opened the door, i could see quite alot of water draining out from the area around the mud flap of the driver's side front tire. after driving for a bit, the water appears to drain completely (i can't hear it anymore). so far, this has happened twice. i have an appointment to take it by the dealer but wanted to see if anyone has heard of anything like this. thanks!!! Link to comment Share on other sites More sharing options...
Legacy777 Posted May 12, 2006 Share Posted May 12, 2006 Sounds like one of the drain areas is clogged. That lower section beneath the door sill is open, and if you remove the plastic wheel liner, you should be able to look in there. It's possible some leaves and junk have gotten in there. Link to comment Share on other sites More sharing options...
scoobyclimbs Posted May 13, 2006 Share Posted May 13, 2006 The Outbacks mudguards have a large cavity that fills with debris and water ...I go wheelin alot and I always saw puddles....I've since replaced them with a cut to fit guard. Link to comment Share on other sites More sharing options...
subie2 Posted May 13, 2006 Author Share Posted May 13, 2006 Thanks for the info! Link to comment Share on other sites More sharing options...
nipper Posted May 13, 2006 Share Posted May 13, 2006 clean ALL the drains as long as you are at it. Both fenders, the doors, the air cowl under the hood, and make sure the HVAC drain is clear. nipper Link to comment Share on other sites More sharing options...
