87RX Posted May 12, 2006 Share Posted May 12, 2006 So I'm planning on replacing my engines, but not sure if it'll work. My 87 Subaru RX is 1.8L Turbo that currently has an engine that is EA82, which is blown. I wan't to put an engine in there that is EA82T. I have no idea how different these engines are, if anyone know, please help. Link to comment Share on other sites More sharing options...
NorthWet Posted May 12, 2006 Share Posted May 12, 2006 The biggest differences aren't because of the "T" designation, but rather it is MPFI and few other EA82s are. MPFI means different heads, different intake systems, different PCV system, different computer, wiring and fuel systems. All the "T" really brings to the party is a different crossmember and different exhaust plumbing (and some minor intake differences). Link to comment Share on other sites More sharing options...
Sweet82 Posted May 12, 2006 Share Posted May 12, 2006 If all your information is correct, the EA82T should drop right in as that would have been the original engine in the car? Link to comment Share on other sites More sharing options...
87RX Posted May 12, 2006 Author Share Posted May 12, 2006 If all your information is correct, the EA82T should drop right in as that would have been the original engine in the car? No, EA82 was in there when I bought the car. After about a month of driving it, the engine developed a really bad rod knock. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted May 12, 2006 Share Posted May 12, 2006 Core Differences are Pistons and Turbo. EA82T: Has a turbocharger, lower compression pistons. 7.7:1 C.R EA82: No Turbo, flat pistons. 9.5:1 C.R Turbo's are all MPFI. Non-Turbo's came as MPFI, SPFI & Carbbed. -Brian Link to comment Share on other sites More sharing options...
suberdave Posted May 13, 2006 Share Posted May 13, 2006 So I'm planning on replacing my engines, but not sure if it'll work. My 87 Subaru RX is 1.8L Turbo that currently has an engine that is EA82, which is blown. I wan't to put an engine in there that is EA82T. I have no idea how different these engines are, if anyone know, please help. if i read this post correctly you have a EA-82T now. the T means its turbo. even the EA-82T's dont have the T on the block. but if your car is a turbo car now you have an EA-82T in there now. Link to comment Share on other sites More sharing options...
MilesFox Posted May 13, 2006 Share Posted May 13, 2006 find a carb motor and swap all your turbo heads and intakes to the carb block, and there you go. you get ore compression, but spfi blocksmay be too much compression for turbo. Link to comment Share on other sites More sharing options...
87RX Posted May 13, 2006 Author Share Posted May 13, 2006 if i read this post correctly you have a EA-82T now. the T means its turbo. even the EA-82T's dont have the T on the block. but if your car is a turbo car now you have an EA-82T in there now. Thanks for the help. Thats the info I've been looking for. Link to comment Share on other sites More sharing options...
