99 Subaru 2.5RS Transmission Upgrade?
a wrx trans would not be much of an upgrade.
for strength, your option is basically a set of PPG gears which is retarded expensive. dog boxes are cool as hell but expensive as hell.
or you could go to a 4eat which is stronger but saps power.
for better ratios, a 4.44 forester trans or an RA gearset will be better. your top end will suffer though.
2nd is part of the mainshaft so you will need a whole new gearset most likely.
maybe have a stock gearset cryogenically treated, should be like 50 bucks.
take it easy on the clutch dumps and crashing 2nd gear also.
