torxxx Posted May 13, 2006 Share Posted May 13, 2006 Well I tested the Blocked EGR idea today. Did 100 miles of driving with it blocked. Engine accelerates smoother, runs cooler and gets better gas mileage. If you have a carb'd EA82 and dont have to pass emission testing, I recomend that you try this mod out. I just used a chunk of an old fender I had layin around, cut to fit, drilled two holes and stuck it between the EGR valve and the intake. Any feedback on this? Link to comment Share on other sites More sharing options...
leon Posted May 13, 2006 Share Posted May 13, 2006 In theory, it sounds like thats what would happen, havent tried it myself though, Link to comment Share on other sites More sharing options...
bgd73 Posted May 13, 2006 Share Posted May 13, 2006 It is a great idea. I did the same thing not for power but to kill an inert heavy chemical that squeezed into the car sometimes. I don't think Subaru knew at higher mileage engines the result of that egr continuing to function. I got outright nautious as well as passengers. the fix does give a clean power/mileage increase cheaply (nowadays priceless with fuel costs) works on spfi too Link to comment Share on other sites More sharing options...
starkiller Posted May 13, 2006 Share Posted May 13, 2006 pics torxx? pm'ed ya bgd... Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 13, 2006 Share Posted May 13, 2006 If you just disconnect the vacuum line, it's the same as blocking it. It will not open so it's basically a big block off plate itself. Plate serves to make it nicer to look at. If you have the one with the pipe going to the anti-afterburn valve on top, just get an EGR that doesn't have the pipe - such as from an EA81/82 feedback carb model, or an EA82 SPFI model. GD Link to comment Share on other sites More sharing options...
torxxx Posted May 14, 2006 Author Share Posted May 14, 2006 Sorry guys, no pics. I used the block off plate to get rid of that anti after burn whatever its called junk. After more playin around with the car, its UNREAL how much more power and how much smoother it accelerates. Makes me think what else I can take off my carb'd engine thats not already blocked off or removed. ASV is blocked, EGR is blocked, Antibackfire is removed, all vac lines are removed, gutted cats and it runs cleaner than any car with the IM crap on it. I'm going to go visit the IM station and see if it will pass with everythign stripped. We have a visual test that you must pass up here, but I'm gonna tell them I just want it as a test because the car is "STRICTLY" offroad.. lol Damn tree huggin enviro hippies Link to comment Share on other sites More sharing options...
keltik Posted May 14, 2006 Share Posted May 14, 2006 Damn tree huggin enviro hippies Trees need love too. :-p Sounds like you've got a heap of stuff unplugged....how much more can there be!? KELTIK Link to comment Share on other sites More sharing options...
torxxx Posted May 14, 2006 Author Share Posted May 14, 2006 the only lovin a tree needs is the love from the bottom of my sooby when I'm running it over.... Link to comment Share on other sites More sharing options...
torxxx Posted May 14, 2006 Author Share Posted May 14, 2006 It is a great idea. I did the same thing not for power but to kill an inert heavy chemical that squeezed into the car sometimes. I don't think Subaru knew at higher mileage engines the result of that egr continuing to function. I got outright nautious as well as passengers. the fix does give a clean power/mileage increase cheaply (nowadays priceless with fuel costs) works on spfi too So thats what that smell was that I get in my car? I could randomly smell exhaust or a smell from internal combustion. Thought it was the oil leakin on my cat... Link to comment Share on other sites More sharing options...
Subarian Posted May 14, 2006 Share Posted May 14, 2006 If you just disconnect the vacuum line, it's the same as blocking it. It will not open so it's basically a big block off plate itself. Plate serves to make it nicer to look at. That's true if the EGR valve is working properly. With high mileage, it's not unusual for the valve to leak. Carbon tends to build up on the poppet, and then it doesn't close completely. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 14, 2006 Share Posted May 14, 2006 Sure - but a good cleaning and re-install will usually fix that. The EGR is not a consumable - it's designed to be cleaned every 60k, and last the life of the car. GD Link to comment Share on other sites More sharing options...
manxsta Posted May 14, 2006 Share Posted May 14, 2006 Well I tested the Blocked EGR idea today. Did 100 miles of driving with it blocked. Engine accelerates smoother, runs cooler and gets better gas mileage. If you have a carb'd EA82 and dont have to pass emission testing, I recomend that you try this mod out. I just used a chunk of an old fender I had layin around, cut to fit, drilled two holes and stuck it between the EGR valve and the intake. Any feedback on this? yeh, i did all this to my n/a ea82 a while back,egr vacuum off..and the atmosspheric valve on the other side to the intake..im getting 9km / litre..i think that works out to be 35 mile/gallon or more...also with these change,s i was able to get a leaner idle mixture and had to idle the thing down as its efficiency went up noticeably,good stuff:grin: Link to comment Share on other sites More sharing options...
