the_postie Posted May 16, 2006 Share Posted May 16, 2006 anyone put a awd auto into a fwd auto car?What i need to know is can you plug the awd ecu into the fwd loom and does it work,are there any wires missing?I have engine/auto loom from a series1 ej fwd car but i wish to run the awd box. Link to comment Share on other sites More sharing options...
86ruguy Posted May 16, 2006 Share Posted May 16, 2006 you are going to need the wiring for the awd solenoids unless i am mistaken, and you need to make sure the trans and diff are the same gear ratio Link to comment Share on other sites More sharing options...
Legacy777 Posted May 16, 2006 Share Posted May 16, 2006 Are you looking to convert the car from FWD to AWD? I think the wiring is there, however you could use an ohm meter and wiring diagram to verify connectivity between the ecu connectors & transmission plug. Link to comment Share on other sites More sharing options...
the_postie Posted May 17, 2006 Author Share Posted May 17, 2006 Legacy777 said: Are you looking to convert the car from FWD to AWD? I think the wiring is there, however you could use an ohm meter and wiring diagram to verify connectivity between the ecu connectors & transmission plug. the deal is i've got wiring loom from a fwd auto lib which i want to put into my 88 L and fit a awd auto box as part of a ej22 conversion.Yes i could just get awd loom but that just adds more expense,i hoping the fwd loom and awd loom are the same or similar maybe a few wires missing pinouts different.Any ideas where i can get the auto wiring diagrams from? Link to comment Share on other sites More sharing options...
Legacy777 Posted May 17, 2006 Share Posted May 17, 2006 I have some wiring diagrams from my swap write-up. Whether the wiring is the same for overseas models....I don't know. http://www.surrealmirage.com/subaru/swap/electrical.html Take a look and see if you can use anything, and if things match up. Link to comment Share on other sites More sharing options...
the_postie Posted May 18, 2006 Author Share Posted May 18, 2006 Thanks Link to comment Share on other sites More sharing options...
mikie Posted May 18, 2006 Share Posted May 18, 2006 Legacy777 said: I have some wiring diagrams from my swap write-up. Whether the wiring is the same for overseas models....I don't know. http://www.surrealmirage.com/subaru/swap/electrical.html Take a look and see if you can use anything, and if things match up. Thats awesome, thanks for going to all that trouble. The info on the auto trans will be very helpful for me too, i hope ytou dont mind others making use of it. Link to comment Share on other sites More sharing options...
Legacy777 Posted May 18, 2006 Share Posted May 18, 2006 You're welcome to it. That's why I did the AWD & 5MT swap write-up. Link to comment Share on other sites More sharing options...
the_postie Posted May 21, 2006 Author Share Posted May 21, 2006 Pinouts and plugs the same just a few wires missing[fwd indicator lamp A2,manual indicator lamp A6 ,atf temp warning C11,speed sensor 2 A15,solnoid awd C3]could a few more when i pull harness apart. Link to comment Share on other sites More sharing options...
