Dave643 Posted May 16, 2006 Share Posted May 16, 2006 My power window switch on the drivers door for my '92 Loyale died, what years are compatible for this. Do these Subies often have electric window problems? Link to comment Share on other sites More sharing options...
azsubaru Posted May 16, 2006 Share Posted May 16, 2006 They get dirty and you can often clean them without a whole lot of effort. Take the door panel off and you can remove the switch panel with a screwdriver. Then lay it on a towel or large cloth and take it apart. Be careful, there are lots of little parts in there that can fly off - that's why the towel. Then you can clean up the contacts. I use a pencil eraser to clean them. They seem to get dirty about every year or so. Put back to gether and it should be good to go. Link to comment Share on other sites More sharing options...
Dave643 Posted May 16, 2006 Author Share Posted May 16, 2006 Are you talking about the contacts in the switch itself or the connector the switch plugs into? Link to comment Share on other sites More sharing options...
WoodsWagon Posted May 17, 2006 Share Posted May 17, 2006 contacts in the switch. I need to get around to doing it in my loyale. I have to pull on one of my windows at the same time that I try to roll it up to make it go. Link to comment Share on other sites More sharing options...
