Caboobaroo Posted May 17, 2006 Share Posted May 17, 2006 Not a good thing... was getting some more of the vacuum lines and such finished up on it and decided to take it out for a spin. Was runnin great, then power started lagging so I turned around and headed for home. 6 blocks from my house, a terrible terrible sounds came from my engine.... it went SQUEAK, SQUEAK, SQUEAK, KNOCK, KNOCK, KNOCK and then stopped running... not it won't turn over for anything... bah, now I need a new engine.... Quote Link to comment Share on other sites More sharing options...
DrKrazy Posted May 17, 2006 Share Posted May 17, 2006 Damn, did your engine start ticking like crazy before it happened? does it turn over by hand? What do you need, I may be able to help you. I have a few engines sitting around, just waiting for projects. But thinking EJ for the lifted rig, and a special built higher compression EA82T for the RX when I blow the JDM, so my spare engines might not ever get used. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 17, 2006 Author Share Posted May 17, 2006 well I edited my WANTED post so here's kidna the plan now... MPFI NA EA82, gen 2 turbo heads which are on deceased engine, Delta 260 cams which are in my shop in cam towers and new seals, plus all of the extra bolt on stuff I have. 8.7:1 compression ratio plus those cams will make one pretty awesome engine... Yes, she did start ticking really loud right before it died. Bah... what a day. Quote Link to comment Share on other sites More sharing options...
soobscript Posted May 17, 2006 Share Posted May 17, 2006 Ouch! (why didn't you replace the pump from the JY motor?) Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 17, 2006 Author Share Posted May 17, 2006 Ouch! (why didn't you replace the pump from the JY motor?) wasn't a junkyard engine. It came to me from a felow board member for free, had about 120k miles on it, and ran fine when pulled, just had a blown intake gasket. Quote Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted May 17, 2006 Share Posted May 17, 2006 OOOOOOhhhh metal shavings in the oil pan(shudder). Quote Link to comment Share on other sites More sharing options...
Turbone Posted May 17, 2006 Share Posted May 17, 2006 Cams are not a good idea. Ask Tex. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 17, 2006 Author Share Posted May 17, 2006 Cams are not a good idea. Ask Tex. Why's that? Did Tex have issues with them? These are the frist set of Delta 260 cams that were made. I got them from WJM and he was running then with no issues I believe. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 17, 2006 Author Share Posted May 17, 2006 Cams are not a good idea. Ask Tex. Why's that? Did Tex have issues with them? These are the first set of Delta 260 cams that were made. I got them from WJM and he was running then with no issues I believe. Quote Link to comment Share on other sites More sharing options...
jeffast Posted May 17, 2006 Share Posted May 17, 2006 just thought i'd add that you don't need an mpfi block there were no differances if your going to change the heads you can use an spfi block and have no problems i believes Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 17, 2006 Author Share Posted May 17, 2006 just thought i'd add that you don't need an mpfi block there were no differances if your going to change the heads you can use an spfi block and have no problems i believes yes I know this, BUT the MPFI I believe has the higher compression ratio, plus it has the bumg on top of the engine thats threaded for the knock sensor. I'm gonna be looking into some of the differences of these engines still.... Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted May 17, 2006 Share Posted May 17, 2006 yes I know this, BUT the MPFI I believe has the higher compression ratio, plus it has the bumg on top of the engine thats threaded for the knock sensor. I'm gonna be looking into some of the differences of these engines still.... Plus, from the sounds of it, turbo and mpfi blocks have a breather on the crank case for the PCV... at least that's what I thought. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 17, 2006 Author Share Posted May 17, 2006 Plus, from the sounds of it, turbo and mpfi blocks have a breather on the crank case for the PCV... at least that's what I thought. yes, yes they do. Too bad I don't need it:D Quote Link to comment Share on other sites More sharing options...
jeffast Posted May 17, 2006 Share Posted May 17, 2006 well there is one(xt mpfi 4cyl) in co auto salvage right now but i don't have the time to go pull it i'll tell you the next time i see one Quote Link to comment Share on other sites More sharing options...
calebz Posted May 17, 2006 Share Posted May 17, 2006 yes I know this, BUT the MPFI I believe has the higher compression ratio, plus it has the bumg on top of the engine thats threaded for the knock sensor. I'm gonna be looking into some of the differences of these engines still.... If the manual is to be believed, MPFI and Carb are 9.0:1 and SPFI is 9.5:1 All EA82s have the bung for the knock sensor. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 18, 2006 Author Share Posted May 18, 2006 ^^^^ SAWEET!!!! Now to go find an engine! Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted May 18, 2006 Share Posted May 18, 2006 If the manual is to be believed, MPFI and Carb are 9.0:1 and SPFI is 9.5:1 All EA82s have the bung for the knock sensor. I heard the same thing.So far I haven't seen anything low mileage wise.BTW I believe pull n save is having one of those you pull it and carry it for $20 type of things going on this saturday.So how strong do you feel? Check their website.I heard about that going on off of the radio station 106.7kbpi. http://www.pullnsave.com/ Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 18, 2006 Author Share Posted May 18, 2006 I heard the same thing.So far I haven't seen anything low mileage wise.BTW I believe pull n save is having one of those you pull it and carry it for $20 type of things going on this saturday.So how strong do you feel? Check their website.I heard about that going on off of the radio station 106.7kbpi. http://www.pullnsave.com/ Oh I know I can carry out a Subaru engine;) I do think I have sourced an engine up here though for free:D Quote Link to comment Share on other sites More sharing options...
