Monte Posted May 17, 2006 Share Posted May 17, 2006 Anyone found one? If I can get away without drilling, I'd rather not drill the frame. But if I have to, guess I will. Monte Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 17, 2006 Share Posted May 17, 2006 Monte said: Anyone found one? If I can get away without drilling, I'd rather not drill the frame. But if I have to, guess I will. Monte No drilling mentioned here; http://www.etrailer.com/products.asp?model=Legacy&category=hitch&year=1997&make=Subaru&t1=&h=e have you emailed Jamie at www.subarugenuineparts.com to ask if the OEM hitch requires drilling? carl Link to comment Share on other sites More sharing options...
Monte Posted May 17, 2006 Author Share Posted May 17, 2006 1 Lucky Texan said: No drilling mentioned here; http://www.etrailer.com/products.asp?model=Legacy&category=hitch&year=1997&make=Subaru&t1=&h=e have you emailed Jamie at www.subarugenuineparts.com to ask if the OEM hitch requires drilling? carl Thanks, those are all drillers. I found one no drill, but it's only a Class I, I need a Class II. I'll ask Jamie about the OEM units. Monte Link to comment Share on other sites More sharing options...
outback_97 Posted May 17, 2006 Share Posted May 17, 2006 Subaru doesn't make hitches, so "OEM" is probably a similar unit to the one linked above. And it will most likely require drilling. I actually have a Class II Drawtite hitch for my 97 OBW sitting around, just haven't installed it yet. Steve Link to comment Share on other sites More sharing options...
Andyjo Posted May 17, 2006 Share Posted May 17, 2006 I think i have a Resse (?) hitch.. and all i did was unbolt the town hooks in the back, and it bolted right up to where those used to be... 6 large bolts... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 17, 2006 Share Posted May 17, 2006 outback_97 said: Subaru doesn't make hitches, so "OEM" is probably a similar unit to the one linked above. And it will most likely require drilling. I actually have a Class II Drawtite hitch for my 97 OBW sitting around, just haven't installed it yet. Steve My WRX came with it as an installed option I bought. I thought it was a bolt on - but '97 could be a lot different from '06 I guess. And it's 1 1/4" the number one installer of hitches in the US is U-Haul. I dunno if they have to drill or not. good luck Carl Link to comment Share on other sites More sharing options...
outback_97 Posted May 17, 2006 Share Posted May 17, 2006 I should have been more clear: I was not aware of Class II hitches for a 1st gen Outback that don't require drilling. The install PDF for the Draw-Tite hitch does mention drilling: http://www.draw-tite.com/fitguides/pdf/N36234.pdf But, the Reese one that Andyjo mentioned might fit the bill. Their web site is http://www.reeseprod.com/ , NOT http://www.reese-hitches.com, that one is a dealer of Reese, and other products. Steve Link to comment Share on other sites More sharing options...
Andyjo Posted May 17, 2006 Share Posted May 17, 2006 http://search.cartserver.com/search/search.cgi?cartid=a-9041&bool=AND&category=combo_makemodel&maxhits=10&keywords=1997&keywords_2=SUBARU+OUTBACK&GO=GO%21 that'll get the job done, click 'click here for more info & ordering' and they have the install pdfs on line, and show if you need to bolt/drill anything. You could also post in the marketplace, one of the board members may have one hanging around for relitivly cheap Link to comment Share on other sites More sharing options...
lmdew Posted May 17, 2006 Share Posted May 17, 2006 I have a good used one, needs a coat of paint. 1" receiver hitch. $40 + shipping from CO 80919 I pulled it off a 97 Outback that I sold. Lmdew@hotmail.com Link to comment Share on other sites More sharing options...
Dr. RX Posted May 18, 2006 Share Posted May 18, 2006 Andyjo said: http://search.cartserver.com/search/search.cgi?cartid=a-9041&bool=AND&category=combo_makemodel&maxhits=10&keywords=1997&keywords_2=SUBARU+OUTBACK&GO=GO%21that'll get the job done, click 'click here for more info & ordering' and they have the install pdfs on line, and show if you need to bolt/drill anything. You could also post in the marketplace, one of the board members may have one hanging around for relitivly cheap WOW, they have one for the extremely rare, never seen Legacy Coupe (look at the second class II hitch). I've been thinking about putting a hitch on the 95 Legacy Wagon, this is good info. Link to comment Share on other sites More sharing options...
JPX Posted May 19, 2006 Share Posted May 19, 2006 The Drawtite ClassII I have on my 1996 sedan required drilling. I'd be surprised if there were any for this body style (OBS included) that didn't. It wouldn't be until the later generations of Legacy/OBS that they were bolt on. Link to comment Share on other sites More sharing options...
lmdew Posted May 19, 2006 Share Posted May 19, 2006 I've used the bolt up from 93 all the way to 98 on standard Legacys and Outbacks. The mounts have plugs in them so the threads do not rust. Pull the plugs and bolt it up. Link to comment Share on other sites More sharing options...
SaltCar Posted May 19, 2006 Share Posted May 19, 2006 I recently drilled holes to mount the hitch on my '96 Legacy. It was really easy, wouldn't hesitate to do it again. Use a piece of wire to lower the bolts through the holes. Your car doesn't have a frame, it is a unibody, all sheetmetal. Link to comment Share on other sites More sharing options...
Wayne Boncyk Posted May 19, 2006 Share Posted May 19, 2006 Hey, Larry! If you haven't found any takers for that hitch yet, I'm up for another drive to the Springs! BTW - That cat set you had laying around was perfect for my '96 OBW, and it passed metro Denver emissions testing with some of the lowest emission numbers I've ever seen from any vehicle! Are you sure that you had THAT MANY miles on them?? Thanks Again for the earlier transaction. Drop me another PM if you still have the hitch laying around. Link to comment Share on other sites More sharing options...
subie94 Posted May 19, 2006 Share Posted May 19, 2006 has anyone installed one on a subie that has a aftermarket muffler with a larger then stock tail pipe.. (click me) Link to comment Share on other sites More sharing options...
lmdew Posted May 20, 2006 Share Posted May 20, 2006 PM Sent, come and get it! I'm glad the cats worked out for you, Larry Wayne Boncyk said: Hey, Larry! If you haven't found any takers for that hitch yet, I'm up for another drive to the Springs! BTW - That cat set you had laying around was perfect for my '96 OBW, and it passed metro Denver emissions testing with some of the lowest emission numbers I've ever seen from any vehicle! Are you sure that you had THAT MANY miles on them?? Thanks Again for the earlier transaction. Drop me another PM if you still have the hitch laying around. Link to comment Share on other sites More sharing options...
Monte Posted May 20, 2006 Author Share Posted May 20, 2006 Every hitch I looked at (Class II) required drilling. I looked at the install sheets for each hitch if I could find one. No a big deal, I'll drill. Thanks, Monte Link to comment Share on other sites More sharing options...
johnceggleston Posted May 20, 2006 Share Posted May 20, 2006 i thought outbacks had a 1000 lbs. max trailer weight. why the need for a class II hitch? Monte said: Every hitch I looked at (Class II) required drilling. I looked at the install sheets for each hitch if I could find one. No a big deal, I'll drill. Thanks, Monte Link to comment Share on other sites More sharing options...
