stavan Posted May 19, 2006 Share Posted May 19, 2006 The lighter of my Subaru Legacy 1990 has been disconnected for some reason. I want to repair and get it working (I need it for my Bluetooth). Haynes Subaru Manual doesn’t say a word about the lighter. My questions are: Where to start? Where it was connected originally? Was it all times on connection or only when the key is in? Any thoughts and suggestions are highly appreciated. Thank you for your time. Stan Link to comment Share on other sites More sharing options...
Gnuman Posted May 19, 2006 Share Posted May 19, 2006 The lighter of my Subaru Legacy 1990 has been disconnected for some reason.I want to repair and get it working (I need it for my Bluetooth). Haynes Subaru Manual doesn’t say a word about the lighter. My questions are: Where to start? Where it was connected originally? Was it all times on connection or only when the key is in? Any thoughts and suggestions are highly appreciated. Thank you for your time. Stan Powered only when key is on (or acc). there are a couple of connections: Power - single wire to center rear. Light - two line connector to the side (IIRC, I'll have to look) Ground - spade plug on the rear side. For easiest access, take the kick panel off. That is the lower part of the dashboard under the steering wheel. You will need a flashlight, and a healthy dose of patience. I hope you have small fingers. It is a bit tight and awkward getting to it. Link to comment Share on other sites More sharing options...
subie94 Posted May 19, 2006 Share Posted May 19, 2006 you can also get access to it by ways of the radio opening....(of course after removing the radio) IMO-that's the easiest way.(i know,hard to believe) Link to comment Share on other sites More sharing options...
stavan Posted May 20, 2006 Author Share Posted May 20, 2006 Thank u guys! I will try removing the radio this weekend. The problem might be there because the radio has been changed... other connections are fine because the light (green ring around lither) is OK. One question though: subbie94, do you remember which cable is it when I open the radio... Well I have to test them... I guess thanks again Link to comment Share on other sites More sharing options...
nipper Posted May 20, 2006 Share Posted May 20, 2006 Two wires to the lighter itself. They dont have much slack on them thats the reason they fall off alot. Its a very easy job and self explaintory when you see the wires. One is black thats the ground goes on the outside of the lighter. The other wire goes to the center. it is possible the l;ighter is dead, and its easy to replace. nipper Link to comment Share on other sites More sharing options...
subie94 Posted May 21, 2006 Share Posted May 21, 2006 here's a pic of the assembly from my 94 legacy...should be the same. green wire's power. black wire's ground. the two red wire's for the light. pull the fuse for the cig lighter assembly first. to remove the assembly,disconnect power wire and remove light.then you have to loosen the metal ring (counter-clockwise?)you may need a flat head to push against the grip bumps(lack of knowing the exact word for the part of the retainer ring) once you remove the ring,it'll come apart pretty easy.(self-explanatory) once removed,you can just test it with a multi-meter. i had to replace mine awhile back cause of a small wire that was broken... Link to comment Share on other sites More sharing options...
stavan Posted May 22, 2006 Author Share Posted May 22, 2006 Thank you guys for your help! It’s all done and working. I accessed my lighter from the radio opening. It took me a few minutes. This is the greatest forum I’ve ever seen. Wishing you safe and enjoyable driving. Stan Link to comment Share on other sites More sharing options...
subie94 Posted May 22, 2006 Share Posted May 22, 2006 Thank you guys for your help!It’s all done and working. I accessed my lighter from the radio opening. It took me a few minutes. This is the greatest forum I’ve ever seen. Wishing you safe and enjoyable driving. Stan it's no prob...anything to help out another subie owner. i know how you feel(i love this place,i spend hours here at times) Link to comment Share on other sites More sharing options...
redsox f.f. Posted May 23, 2006 Share Posted May 23, 2006 To anyone else reading this when i was putting in a new radio on my 98 outback i spliced the power to my cig lighter to a always hot wire so i could charge my phone while i'm away. it works great. Link to comment Share on other sites More sharing options...
