EJ clutch for EA Box?
peejay
Hi
I've got an EJ20G connected to an AWD RX turbo box, using the EA82T clutch and flywheel, but the clutch needs replacing now and it would be nice to get something a bit stronger.
Is it possible to use, say an EJ22 clutch and flywheel, in the above setup? This is an offroad beast so I'm not going to hammer the poor thing (much) so I don't need a hydrolic clutch or anything serious lke that. Just looking for a cheap upgrade while it is all apart.
Youre clutch plate should be interchangeable with any wrx plate, they are the same spline and should both me 9". You could get an aftermarket ceramic with a sprung centre, or Clutch industries in aus even make a ceramic plate with sprung centre and leaves so you keep most driveability but get a decent upgrade in power handling. You would probably have to get youre cover rebuilt as a heavier unit, unless CI do upgraded EA82 covers as well.
you can use any clutch disc from the WRX, but it sounds like you need a better pressure plate. i would rather use an organic clutch disc w/ a heavy duty pressure plate than a 4 or 6 puck disc. if you wheel this beast you need finess, not power. i love my XT-6 disc w/ XT-6 pres. plate mated to EJ22 for wheelin'.
~Josh~
