cole098 Posted October 28, 2003 Share Posted October 28, 2003 Whats a pitching stopper???????? and how do you adjust it.... Thanks Joe Link to comment Share on other sites More sharing options...
North Ursalia Posted October 28, 2003 Share Posted October 28, 2003 It stops the forward rear "pitching" of the engine on its mounts, and I wasn't aware they were adjustable :-). Link to comment Share on other sites More sharing options...
bushbasher Posted October 28, 2003 Share Posted October 28, 2003 if the bushings are gone then your engine can knock back and forth. If you get someone to engage the clutch in gear while the e-brake is up, as if trying to move, with the hood up you should be able to see if it has too much play. Link to comment Share on other sites More sharing options...
cole098 Posted October 28, 2003 Author Share Posted October 28, 2003 Oh Ok... I looked in the subaru factory manual and cant find the pitching stopper in the index.. I will look again... So dO I need to order a new one along with trans and motor mounts... Do you think its exspensive??? Link to comment Share on other sites More sharing options...
bushbasher Posted October 28, 2003 Share Posted October 28, 2003 no idea, everything I get comes from the junkyard. Link to comment Share on other sites More sharing options...
Dennis Posted October 28, 2003 Share Posted October 28, 2003 The pitching stopper is a rod that mounts at the rear of the engine on one end and just under the spare tire holder on the other end. There's a bushing on either end that could be worn, and it should be easy to check visually. If yours is bad, you should be able to pick one up dirt cheap from a junkyard. North Ursalia is right, the pitching stopper isn't really adjustable. There's a little bit of play where it connects to the bracket on the rear of the engine, but that probably won't do you any good. Link to comment Share on other sites More sharing options...
moosens Posted October 28, 2003 Share Posted October 28, 2003 Joe,I've got a few.Which vehicle do you need it for? Non adjustable type only. Link to comment Share on other sites More sharing options...
"EJ" Posted October 28, 2003 Share Posted October 28, 2003 Aren't EA81 type adjustable? The picture posted I beleive is an ea82, mine is adjustable. I know it is because if it is to tight forget trying to start the engine because it bind's the flywheel and the starter. If you get one from a yard make sure you remember which way the washers and rubber pieces go so you can put it back together correctly... Link to comment Share on other sites More sharing options...
archemitis Posted October 28, 2003 Share Posted October 28, 2003 ea81s and ea82s are different types. to adjust the ea82 style you have to bend it to shorten it, and thats all you get. on the ea81 its on a long screw, and mine is double nuted, and is adjustable about 2inches. i think you pretty much center it on ea81s, what car are you asking about? Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted October 28, 2003 Share Posted October 28, 2003 cole, while you drive te car, does your 4wd shifter kinda jolt or move down a ways? if so, i suggest also checking a bolt where your tranny links up to it's mounts or whatever, it is on the pass. side of the trany. hell, it might help. Link to comment Share on other sites More sharing options...
subynut Posted October 28, 2003 Share Posted October 28, 2003 Is that why my alt to rad cap clearance has dropped to the point that I cant even put my finger between them? Used to be that I could just pull back on the rad a little and take the cap off. NOW I can't even do that! :cornfuzz: Link to comment Share on other sites More sharing options...
Sweet82 Posted October 28, 2003 Share Posted October 28, 2003 Get an EA81 pitch stopper. They are adjustable! Just put the mount in the Subuggy. How much play should be in the pitch stopper? I know nothing! Glenn, 82 Hatch, ...well it used to be......:temper: 01 Forester, still is a Forester....... Link to comment Share on other sites More sharing options...
cole098 Posted October 28, 2003 Author Share Posted October 28, 2003 The ea81 I have is a 1984 wagon 4 speed 4wd..... Boy you guys know everything about these cars.... Holy Cow Batman Link to comment Share on other sites More sharing options...
lrgvanman Posted March 2, 2016 Share Posted March 2, 2016 (edited) Does slop in the pitching stopper have any relation to the 4WD light lighting with certain speeds while in FWD? After 60 the light lights. I hold down the Dual Range selector and the light stays out. I have an EA81 1984 GL Station Wagon 4 spd. Dual Range. The pitch stopper is a threaded rod type. UPDATE! I discovered that a "pitch stopper" adjustment stopped the 4WD lamp from coming on. The pitch of the drivetrain triggered the light switch. Problem solved. Had bad mounts; trans and motor! Edited July 11, 2021 by lrgvanman Self discovered the answer to my question. Link to comment Share on other sites More sharing options...
firehawk618 Posted March 4, 2016 Share Posted March 4, 2016 (edited) Holy back from the dead batman!I'm pretty sure it has zero relation to the 4wd light but someone with EA81 experience will chime in.I know on my 1986 EA82 the "LOW" light can flicker on and off if the shifter's bouncing around too much.The low light is a simple button that the shift lever pushes on when it's in the low position and if the handle jiggles around the button goes on and off. Edited March 4, 2016 by firehawk618 Link to comment Share on other sites More sharing options...
TomRhere Posted March 4, 2016 Share Posted March 4, 2016 I would check for worn-out/broken trans mounts 1st. 1 Link to comment Share on other sites More sharing options...
lrgvanman Posted March 4, 2016 Share Posted March 4, 2016 Thanks about the mounts. I sort of guessed them as well. About 60 mph the vibes start and then the occasional, sometimes steady, lighting begins. Link to comment Share on other sites More sharing options...
