TheYeti Posted May 23, 2006 Share Posted May 23, 2006 It is a 1988 GL wagon. The previous owner stated that it runs warm with the air on. Everything is fine with this vehicle... at least everything that I have seen. It clearly has been well maintained through out its 197k lifetime. Do the older gens tend to run warm, or could it be that the old radiator needs to be replaced? Just curious Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 23, 2006 Share Posted May 23, 2006 ... Do the older gens tend to run warm, or could it be that the old radiator needs to be replaced? Just curious Yes, but only when radiator / Thermostat gets clogged... I suggest to check `em out and clean... but still a li`l warmt is "Normal" ... at least on all EA82 I have seen... but Not Overheat. Good Luck! Link to comment Share on other sites More sharing options...
mikeshoup Posted May 23, 2006 Share Posted May 23, 2006 Check to see how warm that 'warm' is. You may find its nothing out of the unordinary. Link to comment Share on other sites More sharing options...
TheYeti Posted May 23, 2006 Author Share Posted May 23, 2006 Thanks. That is what I needed to know. Link to comment Share on other sites More sharing options...
jimkup Posted May 23, 2006 Share Posted May 23, 2006 My "88 DL Wagon (now has 250K+ miles & going strong) ran warm especially with A/C on & stop & go traffic. It really gets hot here in Texas. I did everything ...water pump, thermostat, system flush...but the thing that worked was installing a double core radiator on place of the factory single core. It was not an exact bolt in replacement, but with minimal engineering, it did the trick. Bought the thing on-line, but I don't recall who from. Do some searches for radiators & you'll find one. Link to comment Share on other sites More sharing options...
